Thread started 08 Aug 2008 (Friday) 15:16
How does the flash attach securely to this eBay bracket?
GregSteer
Aug 08, 2008 15:16 |  #1
The item in question..
The eBay auction (external link)
I'm looking at getting a cheap stand/bracket/umbrella to practice with - its a 580 EXII going on it.
The question: From the image in the auction there does not appear to be a way to securely attach the flash unless it's simply relying on the locking pin?
Can anyone shed some light ?
Regards
Greg.
"Never trust a man, who, when left alone in a room with a tea cosy, doesn't try it on" - Billy Connolly - [Gear] - [Flickr] (external link) - Call me Greg
lefturn99
Aug 08, 2008 15:35 |  #2
Why would you buy such a nice flash and try to save such a few bucks on a cheap mount? Sorry, but that doesn't make sense.
6D, 5D Mk III, 60D, EOS M, Gear List
GregSteer
Aug 08, 2008 15:38 as a reply to  @ lefturn99's post |  #3
Well ultimately the flash ended up at ~£180 so not a "massive" amount.
If that cheap mount really isn't worth it and won't do the job then I'll invest in something stronger (if anyone wants to point a suitable mount out then please do) but if it would then why spend the extra if its not needed?
squigles
Aug 08, 2008 15:54 |  #4
I have the very same Bracket mount, it's sure don't feel or look cheap. The top has an adjustable plate that locks against the side of the Flash allowing you to move the flash up and down the slide :-)
My Canon Gear
POTN flickr (external link)
GregSteer
Aug 08, 2008 16:02 as a reply to  @ squigles's post |  #5
So you've no concerns about it holding a flash in safely then? Lefturn99's got me worrying about crashes in the background now :)
squigles
Aug 08, 2008 16:09 |  #6
Absolutely none whatsoever ;) It don't have to cost the earth to be good :!:
My Canon Gear
martinsmith
Aug 08, 2008 16:09 |  #7
I have 3 of those. They're pretty good.
[SIZE=1]ms-imaging (external link)
GregSteer
Aug 08, 2008 16:14 as a reply to  @ martinsmith's post |  #8
I still can't see how the top plate secures, ok maybe i'm being paranoid...
Found a UK vendor... eBay link... (external link) looks like the same item but no visible screws to hold the top plates together ?
Aha - another auction!! seems to indicate the screw that tightens it up eBay link (external link) - is this similar to yours ?
squigles
Aug 08, 2008 16:24 |  #9
Yeap that's the kiddy :-)
My Canon Gear
GregSteer
Aug 08, 2008 16:44 |  #10
Thanks for the confirmations Squigles and Martin - bid placed at a massive amount of £4.49 including a optical slave trigger (that probably won't work on this old spare flash I've got but hey :) )
Time for another chilled beer. Hobgoblin I think.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Aug 08, 2008 21:28 |  #11
For what it's worth, I just bought some name brand "Impact" versions of this from B&H for about double the cost of those you link to, and your E-bay ones look (from the picture) a lot better!
CDS' HOT LINKS
martinsmith
Aug 11, 2008 02:59 |  #12
A pal paid 4x as much for Callumet ones and ended up buying the ebay ones to replace them after seeing mine as they were better quality.
The optical slaves are very good too, unless you use them outside in bright light. Indoors I've never had a missfire.
GregSteer
Aug 11, 2008 13:15 |  #13
Should be with me soon - along with a couple of light stands and two umbrellas - just need another mount and - oh yeah, another flash :) hehe - the wifes going to love me.
GregSteer
Aug 16, 2008 05:41 |  #14
Well it turned up.
Pros:
- It's strong enough for me to be happy, seems a "good" build quality
Cons:
- The locking screw for the top plate is a bit fiddly for me, going to get my dad to turn up a larger one on his lathe.
- My 580 EX II doesn't mount properly! The weather sealing hood fouls against the mounting block so it only attaches right at the rear of the block and doesn't grip correctly due to the off centre pivoting. Works fine when attached to an optical slave adaptor but the only one I have is plastic and I don't trust it to hold the weight.
Can anyone (UK side) suggest a strong hotshoe adaptor of some sort (and supplier - I have a damn hard time searching for the right words for these thing) - only after it to mount doesn't need any functionality...
EDIT: Found One (there's always a first time) - http://www.7dayshop.co​m …rers_id=&produc​ts_id=8381 (external link) :)
martinsmith
Aug 17, 2008 06:49 |  #15
I just took a file to mine.
2,424 views & 0 likes for this thread, 8 members have posted to it.
2697 guests, 136 members online
