Thread started 08 Aug 2008 (Friday) 21:35
Non-sweaty Back Pack
Simoli
Aug 08, 2008 21:35 |  #1
I have a Lowpro Trekker backpack which sits directly against my back. When hicking in the Alps this summer I was getting quite the sweaty back. My cousin had a non camera back pack which actually didn't rest on his back. His sat about a half inch away with only strips touching his back. Needless to say his pack let air circulate which made him much cooler. Is there something like that for photo equipment?
Jim (external link)
www.simoli.net (external link) || Gear List
Anke
Aug 08, 2008 23:06 |  #2
Simoli wrote in post #6073926 (external link)
My Tamrac Expedition 5 has those things, they're quite thick but you still get air flow through some channels.
Anke
PacAce
Joined Feb 2003
Aug 09, 2008 12:07 |  #3
Anke wrote in post #6074314 (external link)
Yeah but there's still enough real estate touching the back to make that part sweat like a pig. When you're wearing loose clothing, the "channels" built on the the backpack really doesn't help much with the air flow.
...Leo
PacAce
Joined Feb 2003
Aug 09, 2008 12:20 |  #4
PacAce wrote in post #6076556 (external link)
However, the Expedition 5 does have a waist belt you can use (I don't use mine) so that the bottom of the backpack rests on your back at waist level. You can then loosen the shoulder strap enough so that the top of the backpack falls away from your back and doesn't touch it. But I'm not sure how comfortable that would be over time with the center of gravity of the backpack behind you instead of close to your body when the backpack is touching the length of your back.
...Leo
alexg
Aug 09, 2008 18:05 |  #5
i dont think there are many options short of using trail pack which rests on your hips and can just hang off your shoulders... if the backpack doesnt have solid support which can curve the surface away from your skin, it will sweat no matter what... the only way to avoid sweat is to avoid or minimize contact.
unfortunately i dont know of any camera gear pack with that feature. however, being captain obvious, messenger back doesnt have that problem :P
7D, 10-22mm, 35 f1.4L, 24-70mm f2.8L, 50mm 1.8
Anke
Aug 09, 2008 18:13 |  #6
How about a non-camera backpack that has this function and then convert it somehow with dividers?
Anke
1,385 views & 0 likes for this thread, 4 members have posted to it.
2854 guests, 164 members online
