Thread started 09 Aug 2008 (Saturday) 22:39
Intermittent overexposed shots
Chosenbydestiny
I somehow feel enlightened now
Aug 09, 2008 22:39 |  #1
I have this weird issue when I'm shooting at the club where I work that I didn't have before... or was I just lucky the first 3 weekends?
The equipment is as follows: Canon XSi with off shoe cord connected to stroboframe flash bracket connected to canon 580EX II flash.
I have everything on manual... and I'm using a custom white balance with spot metering. Shooting jpegs because the club likes to upload the shots before the guests get home.
Just recently, I started getting these intermittent overexposed shots. Sometimes 4-5 in a row, especially if I do continuous mode. Every other shot I have is exposed just perfect, and then randomly I get the overexposed shots that seem to be almost white images. And I didn't shoot any differently than I did the other days, nor was it a different environment. I look at my flash after setting it to -2/3 power and it resets back to 0 every now and then for some reason... Which still doesn't explain the ridiculously overexposed near white images because at +0 it wouldn't overexpose to that magnitude. Do you think I may have accidentally enabled a setting where it would cause these intermittent overexposed shots somewhere?
- Ryan, photographer/videograp​her
Bodies: Canon 1D mark III, 5D Mark III, 5D classic, 6D, 7D, and 60D. Lenses: Tokina 11-16mm f2.8, 24mm f/1.4L II USM, 85mm f/1.2L II USM, 135 f/2L USM, some L zooms, lots of lighting equipment and video support systems Facebook (external link)
Curtis ­ N
Master Flasher
Aug 09, 2008 22:45 |  #2
It's probably an electrical connectivity issue. Remove and reconnect the cord to the hotshoe, and the flash to the cord. Maybe clean all the contacts with a pencil eraser. Make sure everything is secure.
Chosenbydestiny
Aug 09, 2008 22:56 |  #3
Curtis N wrote in post #6078956 (external link)
Thanks Curtis, you seem to always have the answers, heh. I'll try this again with clean contacts tonight.
DDCSD
GIVIN' GOOD KARMA
Aug 09, 2008 23:08 |  #4
Mind posting an example of a good shot fromt he evening, along with one that didn't go right?
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
Chosenbydestiny
Aug 09, 2008 23:38 |  #5
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://img.photobucket​.com …senbydestiny/IM​G_0220.jpg (external link)
<- bad
http://img.photobucket​.com …senbydestiny/IM​G_0318.jpg (external link)
<- good
http://img.photobucket​.com …senbydestiny/IM​G_0124.jpg (external link)
<- good
All same settings, or at least very very close between 1/10th and 1/13th shutter, with f/stop of 3.5 and 4.
Do you think it's the spot metering that makes it do that? Or could it even be the fact I'm using 2nd curtain? The only thing I've done to try and fix the issue so far before Curtis mentioned his answer was turning the flash and camera off and back on.
PacAce
Joined Feb 2003
Aug 09, 2008 23:47 |  #6
I agree with Curtis. It's most probably the contacts. I bet your flash is switch between ETTL mode and TTL mode. When it goes into TTL mode, it'll fire at full power. If the problem is not due to dirty contacts, check to see if the hot shoe is lifting off of the camera body (the screws holding it down may be coming loose).
...Leo
Chosenbydestiny
Aug 09, 2008 23:57 |  #7
PacAce wrote in post #6079188 (external link)
Actually, I forgot to mention that, sorry. =P I did see it in TTL mode once and was wondering why the hell it was in it.
PacAce
Joined Feb 2003
Aug 10, 2008 00:24 |  #8
Check out this thread for what to do if it is your hot shoe being loose:
https://photography-on-the.net/forum/showthre​ad.php?t=541425
...Leo
DDCSD
GIVIN' GOOD KARMA
Aug 10, 2008 00:55 |  #9
Yup, just follow what Curtis and Leo say. Nothing explains that bad of an overexposure, other than a bad connection. Otherwise, send the camera in.
Derek
DDCSD
GIVIN' GOOD KARMA
Aug 10, 2008 00:56 |  #10
Is that MC Hammer in No 2? ;)
Derek
tim
Light Bringer
Aug 10, 2008 02:13 |  #11
Also if you're shooting ISO3200 with a wide aperture and direct flash the flash can't turn down low enough and blows out the subjects. Don't think that's what happened as the background is just about blown too.
Chosenbydestiny
Aug 10, 2008 05:01 |  #12
I'm shooting at 800 or 1600.
BTW, I found out what it was... Thank goodness it wasn't my flash or my camera. It was my off-shoe cord.... =(
Alas, after shooting tonight, I didn't get that bad of a difference from being without it I suppose.
And I don't know if that's MC Hammer, but it sure does look like him.
1,743 views & 0 likes for this thread
Latest registered member is dannykastle
1147 guests, 197 members online
