Thread started 10 Aug 2008 (Sunday) 13:00
How to take self-portraits?
Leo2008
Aug 10, 2008 13:00 |  #1
I was checking out the self-portraits thread and most of them are really AWESOME!. I tried to take it myself but most of them are OOF. How did you all do it? Please do share so newbies like me can learn.
Thank you! :D
tim
Light Bringer
Aug 10, 2008 19:45 |  #2
Do you have a link to the thread?
I'm planning on doing self portraits in a day or two. I'll have my camera on a tripod, manual focused to where i'll be standing. I'll have a remote shutter cable, or maybe i'll use the timer. I'll have my lights triggered using radio slaves. That's as much planning as I think I need to do.
Persephone
Aug 10, 2008 20:22 |  #3
Just hold it in front of you with both hands. Hit the * button until you hear the sound. Shift around (hold the weight into the right hand) so that your index finger can click the shutter and then click. Note: only tried with the 18-55mm II. Your results may vary.
Gear list
"Do you think it was my choice to wed a man I did not love? Live a life I did not choose? I was betrayed by the very gods that once saw me as their own. But no more." - Περσεφόνη (external link), God of War
dbvirago
Joined Feb 2006
Aug 10, 2008 20:26 |  #4
I was using softboxes. I had my main light in a 24x36 softbox set up with a vertical orientation. The top of the box was a little higher than my head so the logo was at head level. I set it on my mark so the side of the box with the logo would be on the same plane as my face. I focused on that, move the box back in position and took my mark. It worked pretty will.
Darryl
http://www.brooksimage​s.com (external link)
http://www.facebook.co​m/brooksimages (external link)
http://twitter.com/#!/​dbvirago (external link)
Nordly
Aug 10, 2008 22:43 |  #5
I took this a week ago, and had my camera set up on a chair across from the bed. I intially focused on the end of the bed, and manually front focused the lens a touch from there as I knew my face would be closer. I spent probably a half dozen frames finding a pose I liked, and adjusting the focus between shots. I got up and reviewed the photos between each frame taken - which is slightly exhausting, but rewarding when I finally got it right.
poloman
Aug 10, 2008 22:47 |  #6
Using a box or other object to take your place and a fairly high f stop will give you the best chance of success. Focus on the box then turn off AF, take your place and shoot.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
Leo2008
Aug 11, 2008 23:42 |  #7
tim wrote in post #6082867 (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=365338
Nordly, that's a nice picture but you look Sad!:)
Thank you for all your suggestions! I will try that soon and post the pictures here.
tim
Light Bringer
Aug 12, 2008 05:21 |  #8
I had a quick play today, I have a quick self portrait in my avatar, i'll do a big version once I refine the technique. I just had two AB800 strobes, one on side of me, behind me pointing down, on minimum power. Camera ISO100 F6.3. For a while I had a 580EX as well to bring out my head, but I took it off after a while. It was kinda fun and i'll keep playing around when I get time :)
whiskaz
Aug 12, 2008 12:43 |  #9
Some good tips I've heard (but never bothered to implement) are 1) putting something where you plan to be located, camera on a tripod, focus on the object, set the lens to MF (unless you use the * to focus), move into position and shoot (timered or triggered). 2) When there's no/little ambient present, use a small flash light or laser pointer, holding it on the same plane as your eyes (or wherever you want the focus to be), use the auto-AF-point select mode (never use it, don't know the name of it), and use a trigger to lock focus. It should lock focus on the light (you may need to move the light around a little to find an AF point). Click.
The second method should allow you to use larger aperture for less DOF. Of course you can also shoot at smaller apertures w/ more DOF and just get close.
I hate the process of taking a s/p, but love/envy some of the results I've seen.
Jeremy | Gear List | EyeDigress - A Photoblog (external link) | blinkphotography.net (external link)
"This aggression will not stand, man."
elader
Joined Nov 2005
Aug 12, 2008 19:43 |  #10
wirelss remote on ebay for $25 - half press to focus, full press to click.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
waterj2
Aug 12, 2008 21:53 |  #11
elader wrote in post #6096066 (external link)
Is that the case even if you have CFn. 4 set to put the AF on the * button?
Jeremy(my flickr (external link))
Canon EOS 30D, EOS Rebel K2, S100
Canon EF 28-135mm f/3.5-5.6 IS USM, EF 50mm f/1.4 USM
Canon 580EX II
elader
Joined Nov 2005
Aug 13, 2008 09:29 |  #12
waterj2 wrote in post #6096800 (external link)
hmmn, er... NO. It has to be half press on the shutter.
Eric
FJR1300 rider
Hermeto
Aug 13, 2008 09:41 |  #13
No.
You have to set C.Fn 4 back to default 0 if you want auto focus with the remote..
suesue
Aug 20, 2008 12:25 as a reply to  @ Hermeto's post |  #14
Would a wireless remote work with my camera..Its a Canon A720 is
can you recomend a good setting..I usually use Auto mode & use the self timer (3 pics) so i have 3 chances to pose..i am NEVER happy with the results. :rolleyes:
3,568 views & 0 likes for this thread, 11 members have posted to it.
2646 guests, 155 members online
