Thread started 10 Aug 2008 (Sunday) 21:19
Understanding Light Falloff
doidinho
Aug 10, 2008 21:19 |  #1
Lets say I set up a shot with one light at 45 degrees to a model and a reflector up against her other side. Lets also say the correct exposure is f/8 at 1/200s and ISO 100.
As I move the light farther away from the model (adjusting output to maintain the same exposure) does the reflected light become more prominent?
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
bobbyz
Aug 10, 2008 22:18 |  #2
Why not do the experiment yourself and post the results?
Fuji XT-1, 18-55mm
tim
Light Bringer
Aug 10, 2008 22:37 |  #3
No.
sfaust
Aug 10, 2008 23:22 |  #4
Yes, it does if my mind is still working correctly this late :). It all depends on the light source distance to the subject, and the reflectors distance between the two of them.
Ie, lets say the light source, subject, and reflector are all 5' from each other in a triangle. The light to the subject is 5', but the light source bouncing off the reflector is 10' away since it has to travel 5' to the reflector, then 5' to the light source. The light will be reduced because of the longer distance. Its twice the distance of the light source to the subject.
Now, if you move the light source back 50' lets say. The light source to the subject is 50', and the light source reflected off the reflector is now 55' (50' to the reflector and another 5' to the subject). Its barely longer then the light source to the subject, so the intensity will be about the same.
In the first example, the difference the light has to travel is double, and the light intensity will fall about a full stop.
In the second example, the distance is only 10% longer, and intensity will be very close between the two. So the effect from the reflector will be more prominent than in the first example.
Stephen
Mix of digital still gear, Medium format to M4/3.
Canon EOS Cinema for video.
Commercial Photography (external link)
doidinho
Aug 10, 2008 23:30 |  #5
sfaust wrote in post #6083883 (external link)
Ie, lets say the light source, subject, and reflector are all 5' from each other in a triangle. The light to the subject is 5', but the light source bouncing off the reflector is 10' away since it has to travel 5' to the reflector, then 5' to the light source. The light will be reduce because of the longer distance. Its twice the distance of the light source to the subject.
Now, if you move the light source back 50' lets say. The light source to the subject is 50', and the light source reflected off the reflector is now 55'. Its barely longer then the light source to the subject, and the intensity will be about the same.
tim wrote in post #6083701 (external link)
No.
bobbyz wrote in post #6083631 (external link)
Good idea, intuitively I think that fixed reflector fill is proportional to the distance of the light source from the subject as sfaust has described.
I will have to do this and post the results; however, wanted a deffinitive answer for tonight. I'm going to go w/ my intuition.
Tim, I respect your comments from my previous post and really hope you are correct.
Robert McCadden
MM (external link)
squabman
Aug 10, 2008 23:46 |  #6
I would have thought that the fill is proportional. The fill is based on how much light is reflecting off it, which when you move the light further from the reflector then there is less light reflecting. I would think (now I am no lighting genius, just thinking) that the only way to change the proportion is to move the reflector closer to the subject.
tim
Light Bringer
Aug 10, 2008 23:53 |  #7
Think about the angles, I suspect the light from the reflector will be proportionally less than the main light on the subject as the light source gets further away. It depends which way the light source goes to some extent.
Curtis ­ N
Master Flasher
Aug 10, 2008 23:57 |  #8
Stephen is right.
bieber
Aug 11, 2008 00:10 |  #9
Mmm, inverse square law plus trigonometry. Beautiful stuff ;)
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
PacAce
Joined Feb 2003
Aug 11, 2008 07:22 |  #10
Curtis N wrote in post #6084071 (external link)
Stephen is right.
Curtis is right about Stephen being right. :)
...Leo
TMR ­ Design
Joined Feb 2006
Aug 11, 2008 07:28 as a reply to  @ PacAce's post |  #11
Leo is right about Curtis being right about Stephen being right. ;)
Robert
doidinho
Aug 11, 2008 14:32 |  #12
TMR Design wrote in post #6085392 (external link)
Cool, that means my intuition was right too.
Robert McCadden
MM (external link)
2,429 views & 0 likes for this thread, 9 members have posted to it.
2730 guests, 150 members online
