Thread started 11 Aug 2008 (Monday) 05:49
Been tearing too many ABBCs, what about acrylic?
Headshotzx
Aug 11, 2008 05:49 |  #1
Hey everyone!
After a few months making, using and unknowingly tearing apart countless DIY Paper ABBC bounce cards, I'm thinking of trying out acrylic as the reflector.
My 580EXII is fully Velcro-ed a full loop around the flash, as seen in the following picture:
IMAGE: http://farm4.static.flickr.com/3141/2456906836_7f8583373e_o.jpg
Now, I know there are products out there such as the Flip-It! and other bounce cards, but they're either very expensive or flimsy or, in the case of the cheapo ABBC diy card, easily torn.
So, what dimensions would be adequate for my 580EXII? I'm thinking to go with a flat trapezium shape similar to the ABBC before its mounted. I did some math and was thinking of a vertical length (height) to be about 7". The top length will be 6", and the bottom length will be 3". Curved & buffered edges for safety reasons. Would this do? It'll be mounted ( with velcro ) on the broad side of the flash unless I need to shoot in portrait orientation, then I'll reposition it to the thinner side .
Second question: Will superglue mount a strip of velcro to acrylic? If not, what other alternatives do I have? Double-sided tape didn't do too well on my DIY ABBC because the small strips of velcro kept peeling off.
Third question: Would an orange colored bounce card be as effective as putting a CTO gel over the flash-head itself? I regularly shoot in orange surroundings and since the flash color temp is slightly blue, white balance is always off.
I'm also thinking; If acrylic works well, and if superglue + acrylic holds well, maybe I can mount 3 velcro strips vertically. That'll allow me to adjust how much of the bounce card will reflect light so I'll be able to reduce the amount of catchlights when I want.
IMAGE: http://img246.imageshack.us/img246/8505/card1el9.jpg
IMAGE: http://img246.imageshack.us/img246/2663/card2ps5.jpg
Anyone have any comments?
Zexun | Flickr (external link) | YouTube (external link) |
magicmikey
Aug 11, 2008 06:54 |  #2
Were you using paper for your bounce card? If so, try the craft foam that was recommended in the ABBC video. If you've been using craft foam and tearing it, then you'll have to use something more durable. (I'm not sure how you could tear craft foam.)
Personally, I opted for a Flip-It. At $30, it really isn't very expensive and it's very versatile. You can adjust the angle of the card for different effects - something you won't be able to do with paper, craft foam or acrylic.
Headshotzx
Aug 11, 2008 09:43 as a reply to  @ magicmikey's post |  #3
I see. But I want to get a more even spread of fill-light. When I view the catchlights in a person's eye with the ABBC paper that I use, the brightest spots are concentrated right at the corners of the card where it folds. I'm sure the acrylic won't do that for me..
Jim ­ M
Aug 11, 2008 12:27 |  #4
The acrylic I'm familiar with is brittle and completely inflexible. I'd use almost anything else.
If you don't want something flexible, such as craft foam, then maybe styrene would be a good choice. Back when I was actively model railroading, I used to get white sheets of it at hobby shops. Try one that specializes in model railroading if you can't find it elsewhere. Easy to cut with a score and snap technique and glues with virtually any plastic model glue or solvent glue.
Calendered vinyl sheet or rigid vinyl sheet might be another possibility, maybe even better. Stiff, but flexible. Calendering is a hot roll process that puts a matt finish on both sides. Most of the stuff I'm familiar with comes in 21"x51" sheets. I don't know how easy it is to get in small quantities, but a web search ought to reveal something. If you have a local plastic supply house, they my have lots of ideas.
JMHPhotography
Aug 11, 2008 20:06 |  #5
I recommend the foamies sheets. 33 cents per at Wal-Mart and I bet you can't tear it. Also, being so pliable, you can adjust it's forward projected light pretty easily.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
TMR ­ Design
Joined Feb 2006
Aug 11, 2008 20:15 as a reply to  @ JMHPhotography's post |  #6
I think the ABBC's are great and can do a lot but I have to agree with Mike. The cost of a Demb Flip-It is $30. It's well made, versatile, and works really nicely in landscape and portrait orientation.
I suppose that if you're on a tight budget then that's about $27 more than you might spend on a DIY with fun foam but in the general scheme of things you're going to be making and replacing the DIY's and the Flip-It will far outlast them.
I don't usually recommend that people go out and spend or waste money but I don't think you'd be disappointed if you spent the $30.
My 2 cents.
Robert
Halliday
Aug 12, 2008 01:32 |  #7
Use the foam sheets not paper. I have been using the same one for several months. I stick it in my pocket, it gets beer spilled on it and still looks and works great.
IMAGE: http://www.iowanightlife.com/content/albums/1685/1.jpg
lanceshuey.com (external link)
"Like a mechanic who forgets to wipe his hands on a shop rag and then goes home, hugs his wife, and gets a grease stain on her favorite sweater — love touches you, and marks you forever."
AB8ND
Aug 12, 2008 08:11 |  #8
Instead of all the velcro on the 580 why not go with a speed strap to just wrap around the ABBC and strobe. This is nice DIY one post on the Strobist blog - bicycle inner tube and selfstick velcro.
http://****/5dyya8 (external link)
Jack
airfrogusmc
Gallery: 179 photos
Aug 12, 2008 08:21 as a reply to  @ AB8ND's post |  #9
Heres what I use.
notice the tungten gel for rooms with tungsten light
Home made
IMAGE: http://i4.photobucket.com/albums/y118/airfrogusmc/Cameras/IMG_3620.jpg
Results:
this is not a very good photo but it give you the idea. I usually go with the flash up one stop from the ambient and expose for the flash. So the ambient is a stop down as not to over power and the gel is color balanced for the ambient. I will use a fluorescent gel in that situation and I frequently shoot a ISO 1600.
TMR ­ Design
Joined Feb 2006
Aug 12, 2008 08:33 |  #10
airfrogusmc wrote in post #6092468 (external link)
Heres what I use.
Home made
Results:
Does this mean that you are in Manual mode and underexpose ambient (using camera's metering system) and then dial in +1 FEC?
Robert
airfrogusmc
Gallery: 179 photos
Aug 12, 2008 09:48 as a reply to  @ TMR Design's post |  #11
Manual. Strobe ettl:
if the metered ambient light say is 1/60 at f 2.8 I'll set the camera and strobe for 1/60 at f/4. So that means the strobe is pumping out f/4 and the camera is set at 1/60 f/4 but the ambient is 1/60 at 2.8...1 stop down so it doesn't over power but you still get great detail in the room. Kinda the same way exposure wise I do environmental portraits with larger strobes. I usually set my exposure so the ambient is one stop under what my main light and my exposure is set at. Does this make any sense at all :confused: ?
I hope so.
Headshotzx
Aug 12, 2008 09:57 |  #12
airfrogusmc wrote in post #6092900 (external link)
I hope so.
Yes it does. It's also the way I shoot using flash indoors.
Just an update guys. My school engineering workshop had a few spare pieces of acrylic lying about. The IC helped me cut rectangular 5"x7" pieces of white and blue acrylic and gave them to me for free!
TMR ­ Design
Joined Feb 2006
Aug 12, 2008 09:57 as a reply to  @ airfrogusmc's post |  #13
Hmm, must be a slow morning for me. I'm not quite getting it. Can you elaborate and better explain this method?
Robert
Headshotzx
Aug 12, 2008 10:02 |  #14
TMR Design wrote in post #6092951 (external link)
If I'm not wrong, he's trying to say that correct exposure for ambient is f/2.8. While using flash, he'll underexpose for ambient by 1 stop, shooting at f/4 with the same shutter, and rely on the flash to give a correct subject exposure. The final picture will have the subjects correctly exposed and the background a tad underexposed.
TMR ­ Design
Joined Feb 2006
Aug 12, 2008 10:28 as a reply to  @ Headshotzx's post |  #15
Ahhh got it. Thank you for the clarification. Makes sense now. :D
Robert
3,301 views & 0 likes for this thread, 9 members have posted to it.
2730 guests, 149 members online
