Thread started 11 Aug 2008 (Monday) 07:00
5D f/4 AF vs 30D AF vs 40D
goatee
"nice but dim"
Aug 11, 2008 07:00 |  #1
Ok, so I used to have a 40D with 24-70, and the AF was so good, that there wasn't a massive jump moving from the 40D to 1DMk2. I've since got rid of both, and now have a 30D with all f/4 lenses. One thing I've noticed is that the AF on the 30D is much more 'hesitant' than on the 40D, or 1DM2.
How does the AF on the 5D compare? It has the AF assist points, but it's the initial wait while the camera locks on I'm concerned with - how does it compare with f/4 lenses?
D7100, 50mm f/1.8, 18-140mm f/3.5-5.6, 70-300mm f/3.5-5.6 VR, SB800
https://photography-on-the.net/forum/showthre​ad.php?t=552906flickr (external link)
elysium
"full of stupid banter"
Location: Harrow/London/UK/GB/That Part Of The World/Next To France
Aug 11, 2008 07:03 |  #2
I used the 24-105L on my 5D and it was pin point accurate @ f/4. Produced very sharp and precise results. Seemed to work a lot better when comparing it against my 400D.
Sadly, not been able to compare to a 30D.
You should have tried out the combo when I came around. :P
Everyday, a programmer finds a way of creating an idiotproof program. Everyday, the universe spits out another idiot.....So far, the universe if winning
goatee
"nice but dim"
Aug 11, 2008 07:16 |  #3
I'm not concerned about the IQ when focus is achieved, but, there's a noticeable lag before it starts trying to focus when it's not bang on. I guess a way of describing it, is if on the 1D you have it set to ring of fire, it also has a slight lag, whereas selecting the centre point is immediate.
I've been manually selecting the focus point, and once it gets going it's fine.
elysium
Aug 11, 2008 07:24 |  #4
Hmmm....when im free one day, ill let you know and ill pop round, you can give it a try with my ex-lens. :lol:
elader
Joined Nov 2005
Aug 11, 2008 07:26 |  #5
My 5D hunts a bit more in low light than the 40D. I noticed this with the 135L (f/2) in this situation where I was shooting ISO3200. f/2, 1/100th sec (dark indeed). It would rack back and forth a bit - never saw that with the 40D.
forgive the purple beard - I cant seem to lose the color of the light on his white beard.
IMAGE: http://elader.smugmug.com/photos/348461784_Lfc2C-XL.jpg
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
goatee
"nice but dim"
Aug 11, 2008 07:45 |  #6
elysium wrote in post #6085379 (external link)
Thanks - that'd be really good. Otherwise I can meet you in town if it's more convenient.
goatee
"nice but dim"
Aug 11, 2008 07:47 |  #7
Hehe, I quite like that purple beard! I'm not too fussed about really low light - but in relatively low light levels - like in the shot I posted above, it just waits for a fraction of a second before starting to focus. My concern was just that the 5D came out before the 30D, and so its AF system is getting a little old now.
elader wrote in post #6085384 (external link)
lowrider
Aug 11, 2008 08:57 as a reply to  @ goatee's post |  #8
I've had my 40D about two weeks now. Previously I had a 30D, and yes, it's been my experience that the 40D does auto focus more quickly than the 30D did.
Lou
versedmb
Aug 11, 2008 11:08 |  #9
goatee wrote in post #6085307 (external link)
O
The center point of the 5D is accurate, but its noticably slower than the 40D. The 40D also seems to have more accurate outer AF points; I only trust the center point of the 5D. The 40D focus feels almost instant with USM lenses, with the 5D there is a lag. Its one of the things I hope that the 5D II improves upon.
Michael
goatee
"nice but dim"
Aug 11, 2008 11:29 |  #10
Thanks for the feedback. Well, hopefully we'll find out soon enough :D.
JCheungPhoto
Aug 11, 2008 11:38 |  #11
I went from the 30D to the 5D. Focusing using centre point on the 30D is similar to focusing centre with the 5D. The difference is frame rate, but otherwise not huge difference between the 30 and 5. However I can't say anything about the 40D.
gear
freewebs.com/jcheungph​otography
"prior planning prevents piss-poor performance"
wimg
Aug 11, 2008 11:44 |  #12
My 5D focused more accurately than the 40D, but the 40D focuses faster.
I received the 40D back from Canon last Thursday, and this was one of the things supposed to be fixed, so maybe AF accuracy has improved. I'll see.
Kind regards, Wim
kcbrown
Aug 11, 2008 12:13 |  #13
wimg wrote in post #6086517 (external link)
Have you noticed any difference thus far since you got it back?
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
eelnoraa
Aug 11, 2008 13:01 |  #14
Speaking from experience, 30D AF is same as 5D.
Comparing F2.8 lens on 40D to F4 lens on 30D/5D, the differece will be large. If you put F2.8 lens on both, center AF point accuracy will be the same. 40D will be probably faster
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
Dragos ­ Jianu
Aug 11, 2008 14:12 |  #15
eelnoraa wrote in post #6087006 (external link)
My experience was completely different. Though i have the 20D for comparison. I could never trust the 20D at f/2. Not even the central. The 5D is MUCH more accurate then my 20D. Around 85-90% spot on at f/2 using the central. As for speed i can't tell much of a difference, it's never been a problem. One other thing I've noticed is that the 5D is much better in Servo too. Must be the 6 hidden assist points.
3,260 views & 0 likes for this thread, 10 members have posted to it.
1595 guests, 140 members online
