Hi all,
I'm trying to get a GND filter system for my 40D + 10-22 / 15-55 setup but am so confused with regards to the amount of information and available gear...
First, I guess I would need an adapter ring and a filter holder... is that correct? - If so, based on the research I've done thus far, it appears that the Cokin 77mm Z-Pro Adapter Ring (0.75mm Pitch Thread)
and the Cokin Z-Pro Filter Holder
are good choices. Is that correct? Any better/cheaper alternatives that won't cause vignetting at 16mm? (10mm on crop)
Second, with regards to the GND filter itself, where can I get it? I've searched B&H, but all I've come up with are plain round screw-able filters. I'm looking for a square filter to go with the mounting system above. Can someone point me to a site? Also, any recommended grading levels for general landscaping use? What about the gradient levels? - hard vs. soft? Either one better for landscape photography?
Thanks in advance
