Thread started 11 Aug 2008 (Monday) 12:14
how to auto focus in dark situation
psxindo
Aug 11, 2008 12:14 |  #1
I'm using off camera flash 580ex II with V2 trigger.
My camera is the 30D.
What is the best method of focusing?
The 30D doesn't have an AF assist beam???
I think it uses the built in flash for the assist beam and the light in front of the camera is for red-eye reduction, am I right???
Can the 580ex II on a cactus trigger emit an AF assist light?
I had a shoot a couple of weeks ago in a dark parking garage and I was really really having a hard time auto focusing. I had to do manual focus. But with a f2.8, I had to be dead on, I kind of missed the focus because of it.
I did try to hold a small flash light on one hand and the camera on the other, not easy to do.
just a rant, my friends cheaper Nikon d40 have an assist beam while using off camera flash with v2 trigger.
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
jgogums
Aug 11, 2008 12:27 |  #2
The 580exII has an assist beam.
Check to see that Cfn 5 on your 30D is set to "0" which means the flash is enabled to fire the assist beam.
Also, check Cfn 8 on your 580exII and make sure that is set to "0" (the default) as that also controls the use of the assist beam.
mattograph
"God bless the new meds"
Aug 11, 2008 12:31 |  #3
hmmm...
This space for rent.
Titus213
Aug 11, 2008 12:57 |  #4
All that being said, I'm not sure your 580EXII will emit a focus assist when mounted off camera with a radio trigger.....
Dave
Perspiring photographer.
cytime
Aug 11, 2008 13:55 |  #5
I also hear a laser light pen is perfect just don't point at anyones eyes....
psxindo
Aug 11, 2008 15:44 |  #6
thanks for the help...
Yes, the 580ex II does have AF assist beam when mounted on camera, but when it's off, it doesn't emits it....
Is there a way to emit the AF with the radio trigger??
TMR ­ Design
Joined Feb 2006
Aug 11, 2008 15:50 as a reply to  @ psxindo's post |  #7
I find that in low light the AF focus assist on Speedlight's isn't satisfactory. What I mean is that the AF works best with greater contrast and although you can get the camera to AF in low light with the AF assist beam, adding a small spot of light or some form of 'modeling light' really helps to tighten up the AF.
Robert
evorgsumaf
Aug 14, 2008 14:30 |  #8
I learned this from the Strobist.com (David Hobby) DVD's. He used a little LED flash light that he actually temporarily attached to his lens. I know it sounds crazy, but when you see how he has done it, and how great it works, it just makes sense.
I don't think this is the same one he uses, but it should work:
http://www.walmart.com …ct.do?product_i​d=10196618 (external link)
Brandon
240dreams
Aug 14, 2008 14:37 |  #9
I shot a car last week with off camera 383's. Of course, auto focus was non existent in the dark situation. I used a flash light to light my focus point and to set it with the camera (40d on center point focus). Then I turned the light off, recomposed, and fired my shot. Pretty much the same method that a few members have already mentioned.
When shooting people in low light, I sometimes tell someone to turn on their cell phone so I can focus on it.
msowsun
Gallery: 14 photos
Aug 14, 2008 14:50 |  #10
The 580EX II (or any EX) will emit the AF assist beam off camera if used with the OC-E3 off camera shoe cord. It is relatively easy to extend the cord as long as you like. https://photography-on-the.net/forum/showthre​ad.php?t=123662
If you don't like doing it yourself, you can buy an extended cord here:
.......http://www.paramountco​rds.com/products.asp?c​at=93 (external link)
OR ......
http://michaelbass.blo​gspot.com …accessories.htm​l#StartOCC (external link)
IMAGE: http://www.paramountcords.com/images/asppages/ttlstrgt.jpg
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
tim
Light Bringer
Aug 14, 2008 18:09 |  #11
40D has much better AF than the 30D. The speedlites have an AF assist beam that helps a bit if the range isn't too far, it only works in one shot mode.
queenbee288
Gallery: 17 photos
Joined Dec 2004
Aug 15, 2008 07:33 |  #12
35L and 40D. I could not believe it. see herehttps://photography-on-the.net …hp?t=545301&hig​hlight=35L
BluewookieJim
Aug 15, 2008 08:32 |  #13
I was shooting some spiders in my back yard around midnight last night. The AF assist on my 580exII wasn't quite cutting it, so I just grabbed my little handheld flashlight, illuminated the subject, manually focused, and there it was, follow the link below to see the results.
That was my first time shooting that way, now I'll be much more prepared for next time.
http://photos.kodanja.​net/p892253147/ (external link)
All shots, 20D, 100mm macro, 580exII, tripod mounted, shutter release.
My Gear and Stuff :: My Zenfolio Gallery (external link) :: My Flickr (external link) :: http://photos.kodanja.​net (external link)
Joe ­ Cyr
Aug 15, 2008 08:52 |  #14
When in doubt or camera is struggling... manual focus.
Canon 1D (MARK III),
10d, Elan IIE (old school), 580exII
70-200 f/2.8L, 17-40 f/4L, 85 1.8, 50 1.8 (nifty)
http://josephcyrphotog​raphy.smugmug.com (external link)
blssdwlf
Aug 15, 2008 13:43 |  #15
I've used a laser pointer and line leveler with great effect in pitch black. A flashlight will work in a pinch.
I've been eyeing this laser + light combo with pressure trigger (external link) to have it as a simple mount.
Regards,
Peter
--= gear: 400D / 17-50 / 55-250 / nifty-50 / flash / etc =--
2,423 views & 0 likes for this thread
Latest registered member is LaurensW
706 guests, 312 members online
