cowboylife wrote in post #6086989
Are you talking about settings IN CAMERA???
Not the way you were thinking.
What I mean is: you can save a bunch of settings to each custom setting dial position, and you can also set up the user defined menu. And on top of that, you can set various custom functions (such as whether or not the shutter button activates autofocus).
It takes quite a bit of time to set all that up.
Suppose you need to do something like send your camera in for service. Chances are they'd reset everything back to factory defaults, which means all your customizations would be wiped clean. The same thing might be true if you were trying to troubleshoot an issue with the camera.
So the question naturally arises: is there any way to save the state of all those customizations to the computer so that they can be restored later?
