tatboats78 Member 138 posts Joined Feb 2007 Location: Oahu, Hawaii More info | Aug 12, 2008 14:45 | #1 I need serious help, Please!! I have tried fixing these group formals with no luck. Can some of you photoshop experts help?!? I have original CS, PS elements 6 & Aperture 2. The indoor formals are fine, but the midday light killed me here & fill in flash did me no justice. Thanks for help!! Melanie Benson
Aug 12, 2008 15:24 | #2 ...so give us a clue... what don't you like? 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Aug 12, 2008 15:34 | #3 I think the background is too bright & the faces are too dark (the bridesmaids dresses are also burning my retinas, but not too much I can do about that:lol Melanie Benson
Aug 12, 2008 15:48 | #4 Well i don't think it looks too bad but you could try to use your favorite method of dodge/burn to darken the background a bit. I know that I would probably use LR2 to use the adjustment brush to darken the blue/cyan color of the background and see what that gives me first. But if you don't have LR see what you can do with the burn tool... 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Aug 12, 2008 16:06 | #5 thanks I will try! Melanie Benson
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Aug 12, 2008 16:07 | #6 tatboats78 wrote in post #6094772 the bridesmaids dresses are also burning my retinas, but not too much I can do about that ![]() I like 'em. Not for the color though. Did you lose Digital Photo Professional (DPP)? Get it here
-Douglas- Beware of DOUG More info | Aug 12, 2008 16:24 | #7 I like 'em. Not for the color though.
Edit My Images- OK"Brain Fart" = an essential bodily function.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 12, 2008 16:25 | #8 Shadows and highlights tool will do the job. I don't think it needs to be done though. The histogram at the time of shooting is the best way to do it, expose for the background, flash to light the subjects. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Aug 12, 2008 16:50 | #9 I adjusted the blue/cyan color of the background as suggested & looks much better.thanks Melanie Benson
Bobster Cream of the Crop More info | Aug 12, 2008 17:08 | #10 next time choose a better spot for the photos or use ur speedlite to give some infill flash Robert Whetton
Aug 12, 2008 17:16 | #11 Bobster wrote in post #6095328 next time choose a better spot for the photos or use ur speedlite to give some infill flash The fill flash looks fine to me... i would have simply chosen to under expose the background slightly to help the subjects pop more... like maybe -2/3rds to -1 under where it is now. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Aug 12, 2008 17:23 | #12 Dermit wrote in post #6095357 The fill flash looks fine to me... i would have simply chosen to under expose the background slightly to help the subjects pop more... like maybe -2/3rds to -1 under where it is now. I did use my sppedlite for fill. But I will def. under expose a smidge next time. Melanie Benson
Aug 12, 2008 17:32 | #13 tatboats78 wrote in post #6095381 I did use my sppedlite for fill. But I will def. under expose a smidge next time. Just to clarify... you want to set the underexposure so it effects the background.... so you would not want to dial down the flash... just the exposure in the camera, i.e. faster shutter, smaller aperture, or lower ISO until the meter reads -2/3 to -1 below the level this first image was shot at. You have to watch it because you might start to reach some limitations of the power of the flash (lower ISO and smaller aperture make it work harder), or be limited by a max shutter sync speed with the flash. So your options might become limited. If you are finding that the flash you have simply can't deliver the power needed another option is to move the flash closer to the subjects which means if it is on camera you may need to use a wider angle lens.... ah the options/choices, it's what keeps photography interesting. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Aug 12, 2008 17:46 | #14 Dermit wrote in post #6095428 Just to clarify... you want to set the underexposure so it effects the background.... so you would not want to dial down the flash... just the exposure in the camera, i.e. faster shutter, smaller aperture, or lower ISO until the meter reads -2/3 to -1 below the level this first image was shot at. You have to watch it because you might start to reach some limitations of the power of the flash (lower ISO and smaller aperture make it work harder), or be limited by a max shutter sync speed with the flash. So your options might become limited. If you are finding that the flash you have simply can't deliver the power needed another option is to move the flash closer to the subjects which means if it is on camera you may need to use a wider angle lens.... ah the options/choices, it's what keeps photography interesting. I was assuming that's what you meant, but thanks for clarifying. I really want to get a 10mm or 11-22mm for shooting my weddings. I am actually planning on buying one from the $ from this wedding. I think it would be my best option. Melanie Benson
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Aug 12, 2008 18:14 | #15 Ultra-wides are a bad idea for group shots. They distort things. Did you lose Digital Photo Professional (DPP)? Get it here
| Latest registered member is AlainPre 1788 guests, 164 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
