Thread started 13 Aug 2008 (Wednesday) 09:00
How does high speed sync work?
funk1196
Aug 13, 2008 09:00 |  #1
So as i understood it, the sync speed of my camera (XSI, 1/200) is a camera limitation.
But on my 580ex ii... i can do any shutter speed i want.. and from what i've seen, there's no dark areas from the shutter being in the process of opening and closing.
How does this work, is the 580ex ii really allowing me to do shutter speeds above my 1/200, or is there a downside to doing that that i'm not seeing, or will show up in certain shots.
The mechanics of this is confusing, if anyone has a tutorial of high speed flash to help me understand, that'd be awesome.
5D II, 16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100mm f/2.8 macro.
T1i, 10-22mm, 17-55mm.
580EX II, 430EX II, ST-E2, EF 2X II
Michael
Aug 13, 2008 09:09 |  #2
Yep, it's allowing you to use a higher SS. Because at a higher SS the shutter is never completely open, you need to use HSS. As far as I know, it just keeps the flash on for a longer burst than normal.
I guess it would use more power and cause longer recharge times. I haven't really experimented with it much.
Michael
René ­ Damkot
Aug 13, 2008 09:21 |  #3
The flash gives off a long (about 1/250s at least I'd think) burst of flashes (at about 60kHz IIRC), so it more or less acts as a continuous lightsource. That includes having a chance of motion blur if the shutterspeed doesn't stop it ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Curtis ­ N
Master Flasher
Aug 13, 2008 17:50 |  #4
funk1196 wrote in post #6099306 (external link)
Somebody wrote one.
https://photography-on-the.net/forum/showthre​ad.php?t=208520
3,698 views & 0 likes for this thread, 4 members have posted to it.
2730 guests, 149 members online
