Thread started 13 Aug 2008 (Wednesday) 22:18
Overpowering the Sun (long, but with pics) :)
vince396
Aug 13, 2008 22:18 |  #1
Just thought I'd share a shoot we did last night using.
I was going to do some minor overpowering while shooting photos to composite into a tennis team's poster, kinda like this (for which I used a 430 EX and SB-24):
After I heard that their theme was "Love Means Nothing," I decided that we should make the lighting even more dramatic and menacing. So we broke out the Alien Bees. We used two AB-800s and one AB-400 all powered off of a Vagabond II and fired with CyberSyncs (which I LOVE by the way - I have both AC and battery powered models). We fired at full power and about f/11, 1/250 sec. The setup photos below give you a good idea of how bright it was (overcast 7:00 pm skies).
And the results (these are all as captured in the camera, lighting wise. I did some desaturation and sharpening, but no dodging/burning or any other manipulation):
We used glycerin/water to "sweat up" the players, but it doesn't show well in the low res photos.
In total, we took about 190 photos and the poster will use about a dozen. These are a sample of the ones that I've chosen to use in the poster. All in all, I'm pretty satisfied.
Bucster
Aug 13, 2008 22:54 |  #2
I love the pictures, thanks for showing us your setup
Richard
TPDphoto.com (external link)
MyPhotoStudio.org (external link)
bieber
Aug 13, 2008 22:57 |  #3
I believe that technique is called "obliterating" the sun, not "overpowering" ;)
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
Warrenism
Aug 13, 2008 23:30 as a reply to  @ bieber's post |  #4
These dramatic shots look great.
Would i be correct in saying that most of the samples provided here are predominately lit with 2 lights only located on either side of the subject?
Not sure where the 3rd one sits as i can't see an noticeable catch lights in the eyes nor hairlights.
[DSLR-less | 10-22 | 24-70L f2.8 | 70-200L f2.8 IS | 24-105L f4 | 50 f1.4 ]
Flickr (external link) | Warrenism: Blog Rantings (external link)
vince396
Aug 13, 2008 23:33 |  #5
Warrenism - Actually, you're right! The ones I posted were predominantly lit with two. The pairs photos had an AB400 with a 20 degree grid lighting them from camera position, but at very low power. I had some shots that had more output from the camera position, but there was more fill than I wanted. The tight headshots were all lit with two lights.
Good eye!
bieber
Aug 14, 2008 00:19 |  #6
Warrenism wrote in post #6104178 (external link)
I'm guessing it came into play in that shot with the spot-lit ground...
Warrenism
Aug 14, 2008 00:22 as a reply to  @ vince396's post |  #7
Now if only i had willing subjects to practice upon, i would love to reproduce something nearly half as good as this as part of the learning process of how to manipulate light. :) Its something reminisce of the nike ads that you see in the sporting mags.
Another question, (apologies if this is not in line with the forum topic rules), How do you go about getting a black background on the subjects?
I assume its a couple of variables
- smaller aperture / fast SS - kills ambient
- using the black netting on the fences as the background
- de-saturating the background in PS
Is this correct?
Warrenism
Aug 14, 2008 00:27 |  #8
bieber wrote in post #6104397 (external link)
Wouldn't we see a shadow behind or infront the subject's foot then?
Looking at the front legs, there is quite an apparent cross shadow that appears down the middle of the left.
vince396
Aug 14, 2008 00:42 |  #9
No - the spot lit ground is entirely from the softboxes flanking the player. The honeycomb grid in the reflector of the light over the camera really directed the light (I didn't post the setup photo that showed the grid). The output of that light was feathered over the subjects' heads and was very low in output.
As for the black background - there is no manipulation after the fact. It was all shutter speed. We shot at ISO 100, f/11, 1/250. If memory serves, the ambient light was about f/4 and 1/60 when we started at 6:30 pm. Somewhere in there. So at f/11, we would have had to shoot at about 1/8 in order to get correct exposure (assuming that my memory is correct on the ambient reading - not always a great assumption! - but it's close).
So at 1/250 and f/11, we were underexposing the ambient light by about five stops (and actually more as the sun got lower). So anything that wasn't lit by the two mains (which were at f/11) dropped to black pretty completely.
The tight head shots in front of the fence were done at about 8:15 pm. I didn't take a reading at that time, but my guess is that ambient would have been f/2, 1/30 or so at ISO 100 (purely a guess).
In the shot below we were dialing in the main lights for a group shot. I checked the EXIF on this one. It was shot at ISO 400, F/8, 1/250, so it was three stops brighter than the general exposures we used (two stops of ISO values and one f-stop). This shot is completely unmanipulated except for conversion from RAW to jpg and saving for the web. You can see how much the camera settings alone (mostly the shutter speed) can kill the ambient. Even at three stops brighter than the exposures we used for the final shots, the ambient light is very dark. I assure you that on the court, it wasn't even close to that dark. In fact, you can see that the park lights in the background haven't even come on yet (and they are on light sensors).
vince396
Aug 14, 2008 00:51 |  #10
Warrenism wrote in post #6104413 (external link)
And actually, that was one of the inspirations! We used a mix of glycerin and water to simulate sweat. I've used it tons of times, and it never lets me down!
Warrenism
Aug 14, 2008 01:04 as a reply to  @ vince396's post |  #11
Thanks Vince, your explanations and setup shots have been very insightful! Kudos to you for sharing and divulging some awesome tips to a newbie. :)
vince396
Aug 14, 2008 01:08 as a reply to  @ Warrenism's post |  #12
My pleasure! I haven't done this forever, and I probably learn as much by trying to share it (and probably more!) as you do trying to make sense of my drivel.
I just love that we can have a near instantaneous conversation from Australia to Wisconsin, USA.
Have a great day (I believe it's day there). I, on the other hand, am on my way to bed now that it's after 1:00 am.
BTW, I'm a huge basketball fan, and one of my favorite players of all time was Luc Longley from Perth! He went to college in my hometown.
Warrenism
Aug 14, 2008 01:23 |  #13
vince396 wrote in post #6104602 (external link)
Haha, that was the heyday of NBA indeed. Forget Jordan / Pippen / Malone... it was all about the sole Aussie export!! Luc Longley.
I don't really follow NBA but from what i hear, Bogut is doing a quite a good job over there.
vince396
Aug 14, 2008 01:41 as a reply to  @ Warrenism's post |  #14
I should already be in bed. :)
Bogut is doing quite well. He plays for Milwaukee, which is about 60 miles (100 km - I used to live in Germany - I know my metrics!) from here. But there will never be an Aussie giant like Luc!
Good night!
tim
Light Bringer
Aug 15, 2008 06:11 |  #15
Thanks for sharing, love the photos and played with a similar light setup at home this evening. It works well! I shot a pretty good 4 light self portrait.
3,716 views & 0 likes for this thread, 10 members have posted to it.
2833 guests, 132 members online
