Thread started 14 Aug 2008 (Thursday) 12:58
what card reader ?
Zilly
Aug 14, 2008 12:58 |  #1
Ok guys I need a card reader (well two to be exact)
what's fast, reliable and great priced
Dom
Follow my adventures on twitter (external link)
Car Photography (external link)
sally_tomato
Aug 14, 2008 15:21 |  #2
try looking thru newegg.com
i found my irocks unit there.
--ac.
jureis
Aug 14, 2008 16:19 |  #3
i have 2 of these (external link) on sale this time last year
Bodies: 50D Gripped, 20D Gripped, A-1
24-70/2.8L , 17-40/4L, 85/1.8, 50/1.4, FD 50/1.8, 580EX-II
Anke
Aug 14, 2008 20:48 |  #4
I have a SanDisk Extreme Firewire (external link) which ROCKS!
Anke
bohdank
Aug 17, 2008 00:37 |  #5
Out of curiosity.... how long does it take to dump a 4 GIG card ?
I bought the cheapest reader I could find. Paid $18.99
I just did a small test. I loaded a 4 gig Extreme II card (not the fastest card out there) up with D40D RAW image files (314) and then copied them to my hard drive.
Total time to copy the card to the hard drive was 6:12
I'm sure the Sandisk rocks but by how much ?
Anke
Aug 17, 2008 01:13 |  #6
bohdank wrote in post #6122277 (external link)
My 4GB cards are about a minute-ish. Firewire is lovely :)
Anke
bohdank
Aug 17, 2008 02:11 |  #7
Which card ?
Trying to find out what bearing the card has on the download speed.
Firewire is faster than USB2 in real use....but the writer is specd at 40m/sec. if everything is perfect (it never is). therefore to move 4 gigs would take, at best, no less than 1:40.... still, very very fast with Extreme IV cards.
edit: I just checked Rob Galbrait's tests of card readers. With the Extreme IV it does actually get 40m/sec (slightly under). With Ultra II, the card I tested my lowly reader with, it did 12m/sec. or 5:33 to read 4 gigs. I would save about 39 seconds with the cards I use.
bohdank
Aug 17, 2008 02:33 |  #8
I just did another test with a Transcend 2 gig 133x card. Took 1:25 or 2:50 if it was a, theoretical, 4 gig card. Seems the card has more effect on the speed than the reader. I'll stick with my $18.99 reader and put the difference into more cards.
on ­ da ­ move
Aug 19, 2008 02:12 |  #9
Anke wrote in post #6109853 (external link)
+1 I totally agree! :D
Willy
cdifoto
Don't get pissy with me
Aug 19, 2008 02:15 |  #10
I have Sandisk Extreme USB readers. Cheap as chips, quite fast, and includes a CD of RescuePRO - which is quite good recovery software. My only niggle is they come in a fancy gloss black finish that looks like ass in short order if you do anything more with it than just keep it on your desk. The reasons I went with the USB version over the firewire are A) cost and B) USB version has an SD/SDHC/MMC/MSProDuo slot in addition to the CF.
Viky
Aug 19, 2008 08:14 as a reply to  @ cdifoto's post |  #11
I Have a 4GB Extreme IV and three different card readers - Here are the download times for a full 4GB of 400D Raws
Transcend USB Reader (external link) 323 secs
Sony MRW62E Reader (external link) 194 secs
Sandisk USB Extreme Reader (external link) 118 secs
I had also bought a Sandisk Extreme Firewire Reader that could supossedly reduce this to sub 60secs, however it came with a 8-Pin Firewire 800 interface and would not work on the 4-pin Firewire 200 interface on my laptop:(
You first see a photo with your mind, and then capture it with your camera!
Canon - EOS 50D with BG-E2N | 10-22mm f/3.5 | 70-200mm f/4 L IS | 400mm f/5.6 L | Tamron - 17-50mm f/2.8 VC |Sigma 30mm f/1.4 EX | 150mm f/2.8 Macro EX | Misc - 430EX | OC-E3 | EF-12 | Kenko 2x TC | Panasonic FZ5. My Flickr Album (external link)
Pete ­ Gl
Aug 19, 2008 08:31 |  #12
Viky wrote in post #6136646 (external link)
I intended to buy the Sandisk Extreme Firewire Reader, but, like you, I have only the 4 pin interface on my laptop. Does anybody know if anything SIMPLE can be done to make it work, I'm thinking of some sort of adaptor cable ?
Pete
Fuji X-T30 Body, XF18-55 F2.8-4 R LM OIS, XF55-200 F3.5-4.8 R LM OIS lenses.
on ­ da ­ move
Aug 19, 2008 10:11 |  #13
Pete Gl wrote in post #6136721 (external link)
Pete
Here's a link to Monoprice.com (external link) that sells the 4-pin to 9-pin firewire for less than 7 bucks! This place is very reputable among the home theatre crowd.
Willy
ed ­ rader
"I am not the final word"
Aug 19, 2008 11:06 |  #14
Zilly wrote in post #6107192 (external link)
well i don't like sandisk. my first one died and the one i have now has to be unplugged and replugged to work at times and sometimes the card doesn't go in smoothly.
i won't be getting another sandisk after this one.
ed rader
5D4, 80d, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, sigma 15 FE, sigma 14 f1.8 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Ukuleleman
Aug 19, 2008 11:31 |  #15
$99.99? Henry's is ripping you off! it's a card reader, there are hundreds of them, cheap and cheerful that do the job just as well.
What's the difference between a photograph downloaded from a $100 reader and one from a $25 reader?.....The $25 reader was 75% cheaper! they either do the job or they don't.
There are no shortcuts to any place worth going to
https://photography-on-the.net …p?p=2701981&pos​tcount=461
http://ukuleleman.zenf​olio.com/ (external link)
2,783 views & 0 likes for this thread
what card reader ?
Latest registered member is Isa-FR
721 guests, 228 members online
