Thread started 14 Aug 2008 (Thursday) 19:18
What to Meter??
izzy35
Aug 14, 2008 19:18 |  #1
After reading and reading and reading, I feel like i still need clarity on, how do you know what to meter??? I've read, meter your hand, card, sky, etc....but in what situations and why, do you "meter" something other than what you're actually shooting???:confused:
Canon Xti | Canon EFS 18-55 (Kit Lens) | Canon 70-200 f/4L IS
JeffreyG
Gallery: 42 photos
Aug 14, 2008 19:21 |  #2
You use whatever works for you. All of these metering tips are ways to use the reflected light meter in your camera to evaluate the incident light on the subject. The reason you don't meter the subject is that different subjects have different tones. Your hand (or a grey card) is always the same, but a white swan and a black bouder will meter very differently.
So if you personally decide that you palm metered at +2 stops in the same light as the subject always gives the correct exposure, then use that. If you are standing in shade and the subject is in the sun you quickly realize the shortcoming of this method as you walk the camera over into the sun with your hand to get a reading.
izzy35
Aug 14, 2008 21:10 |  #3
But WHY do you do this?? Meaning, in what scenarios would u meter something else BESIDES the subject...backlit, sidelit, etc...and what is the reason?? thanks all:-)
tim
Light Bringer
Aug 14, 2008 21:16 |  #4
The camera expects whatever you meter to be 18% grey. If you spot/partial meter white it will underexpose (it makes the white look grey), if you meter black it will overexpose (it makes the black lighter to 18% grey). Exposure compensation tells the camera "you're not metering 18% grey, tweak it a bit". If you meter a white dress you use exposure compensation of 1 or 2, to tell it the subject is brighter than 18% grey. If you meter black you use -1 to -2, as it's darker. For fair skin about +1EC is correct. If your main light is flash use FEC (flash exposure compensation) instead of EC. If you're in Av mode flash is fill so adjust the FEC down a little.
18% grey is just what is assumed as typical scene is. If you fill the frame with a persons face with EC 0 it will be underexposed (about +1 required), if you fill it with a dark suit it will be overexposed.
tim
Light Bringer
Aug 14, 2008 21:17 |  #5
You should get the book "Understanding Exposure" (external link), it'll teach you all these things better than we can.
izzy35
Aug 14, 2008 21:33 |  #6
tim wrote in post #6110008 (external link)
yeah i LOVE the book!!! absolutely LOVE IT...have read it about 4 times and re-read all unclear sections daily...LOL ....I just feel that i still don't completely understand WHY you would meter the sky instead of the landscape, the face rather than the whole scene, etc, and then recompose the shot to what you are intending to take the photo of...I just don't know WHEN and WHY to do it....
Hermeto
Aug 14, 2008 21:46 |  #7
When?
Whenever your experience tells you that metering the whole scene can introduce error to your exposure.
Why?
Because you are smarter than camera’s metering algorithms..
tim
Light Bringer
Aug 14, 2008 22:51 |  #8
izzy35 wrote in post #6110099 (external link)
There are two reasons to meter the sky:
- You often expose for the brightest part of the image, and bring up the darker regions in post. Once something's blown it can't come back, but if it's just dark it's easy to make brighter.
- If you're photographing people you expose for the sky and flash to light the people, this prevents the sky blowing out.
bobn15
Aug 15, 2008 00:37 |  #9
I second Brian Peterson's Understanding Exposure...you meter different things depending on the situation
My Gearhttps://photography-on-the.net …?p=1193134&post​count=1362
daduls
Aug 15, 2008 01:55 |  #10
izzy35 wrote in post #6109962 (external link)
I'm no exposure guru but here is an example of how the same subject gives differing results. These were taken less than 10 seconds apart from different angles, however the duck was the focus point in both shots.
The introduction of water in the photo changes the metering algorithm just as a sky would. The result is totally different colors.
These photos are straight from the camera with only a resize for posting and save for web.
Sorry didn't turn them. ...
Stephen
Gear: 1D Mk II | Tam 17-50 2.8 | 28 2.8 | 50 1.4 | 70-200 2.8L
My smugmug (external link)http://swdunn.smugmug.​com/ (external link)Vacation Rig: Rebel XT and 18-55 IS
qtfsniper
Aug 15, 2008 03:16 |  #11
wow that's a huge difference. Are we talking about white balance here (taking a picture of a grey card and having the camera evaluate it) or different actual modes for when the camera uses its like meter to determine proper exposure? I think the OP is asking why would you expose for your hand if the subject is a lot darker? Wouldn't that just underexpose the darker object? Or why meter off your hand if the subject is even lighter, overexposing it.(if that is even what the OP is asking). I could totally wrong and misunderstand everything too.
tim
Light Bringer
Aug 15, 2008 03:33 |  #12
Exposure's similar in each, it's white balance that makes it look a lot different.
Bobster
Aug 15, 2008 03:37 |  #13
if i'm outside, don't have time to get my hand meter out, i take a reading through the camera from a bit of grass thats near by
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
SkipD
Joined Dec 2002
Aug 15, 2008 03:48 |  #14
daduls wrote in post #6111234 (external link)
The difference in colors has nothing whatsoever to do with the exposure level metering. It has everything to do with white balance control - or, rather, lack of it.
I would suspect the camera was set to "AWB" (Automatic White Balance) for the two shots. I learned early on that AWB does not work well in anything but the most "typical" outdoor scenarios and thus I never use AWB. I also shoot in RAW mode so that corrections of white balance problems is simple in post-processing.
Skip Douglas
Mike
ugly when I'm sober
Gallery: 51 photos
Aug 15, 2008 04:41 |  #15
My experience tells me what I should meter from.
For example, I shoot a lot of cricket and in that sport the players all wear white. If I take a meter reading from the whole scene I often get over-exposed whites so (shooting in M) I will try to meter from the whites and then chimp and adjust the shutter speed until the whites look good. The histogram helps tremendously.
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
3,096 views & 0 likes for this thread, 18 members have posted to it.
What to Meter??
2815 guests, 133 members online
