Good article!
710 Studio wrote in post #6113960
FLO - I checked out the discussion you linked to... sadly, it was not very helpful. That discussion contains replies such as, "If you have to ask, use sRGB", which I find annoying, at best. I'm asking, because I want to learn. Personally, I think people who give snide answers like that should be publically flogged... heh heh heh
For more info, you might want to read the link from my sig. Quite a few links about the topic in there
The question, then, is do you have an opinion as to how to achieve best results when converting your RAW images to a print-friendly format?
Depends.
There is no easy answer.
If you print at home, your printer is likely to have a larger gamut (in certain colors) then sRGB, maybe even AdobeRGB.
You can softproof for the paper/printers profile, to get a good screen to print match.
Again: More info in the link from my sig.
Basically, in summary, I guess I'm asking - other than taking great photos to begin with - is there anything else I need to do in post (image conversions, etc) to ensure that my photos print to the absolute best of their potential?
Read the link ....
710 Studio wrote in post #6113973
LOWNER - The article that DOUG PARDEE led me to did an awesome job of explaining that pics for the web should be sRGB, but sometimes A-RGB looks better for print. What if I shoot photos for BOTH uses? My guess would be to just use sRGB at that point?
Thanks for the reply.
If you use an inkjet, and shoot raw, by all means use a wider gamut color space. Provided you know what you are doing.
You can convert an AdobeRGB image to sRGB, but out of gamut colors will be clipped (since the only rendering intent is colorimetric). So some care is needed.
If you shoot jpg, sRGB might be the better choice.
It also depends on subject matter: If your subject contains only pastels for instance, then using AdobeRGB makes zero sense....
710 Studio wrote in post #6114082
Getting good answers is hard to come by, these days...
Probably because there is no "one size fits all"...
But, as I shoot RAW, anyway, it sounds like it just doesn't make a difference.
It does. But not in all cases.
710 Studio wrote in post #6114198
I think I'll just keep it locked on sRGB. I checked out your site, by the way... nice work!
At least until you know why you *might* want to use a different color space....
