Thread started 25 Jan 2005 (Tuesday) 13:23
Plans for building portable studio lighting... (DIY and super cheap)
KevC
Joined Jan 2005
Jan 25, 2005 13:23 |  #1
Heya all,
I can't afford Alien Bees or any studio lights, so I'm gonna try to do as much DIY as possible. Please let me know if it'll work.
I have a desk lamp I'm not using. I slapped a flourescent lamp in there. That's going to be my light source. I'm also going to order a cheap music stand from ebay. Going to fab some sort of reflector from it. I'm thinking aluminum foil and cardboard.
Softbox.... for now I'm going to droop a white cloth over the lamp (with a chair on top... so it spreads the light more. I'm considering fabbing a softbox with white styrafoam but I'm not sure if how that'll hold together.
Studio umbrellas can be found for very cheap on ebay (<$20). I'm not sure of the quality, but this will definitely be better than the lamp directly, correct? I'll hafta figure out a way to mount the umbrella onto the lamp though...
Any ideas on a DIY solution? I'm going to be buying an Alien Bees setup *eventually* (when I move out... ) but for now... I have very limited funds. I haven't even paid off my camera yet!
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
Longwatcher
obsolete as of this post
Joined Sep 2002
Jan 25, 2005 13:35 |  #2
I am not sure your desk lamp will have enough power, especially to get through a white cloth. But for a modest investment, you should be able to get a couple of work lights from Home Depot or equivilent. Just take off the grill on the front. They come with their own light stands. If you do go this route be sure to keep flamable material away from the lights. Your reflector idea should work well enough as long as you keep the foil flat (I recommend using the dull side out). A pair of worklights and a reflector should be more then enough to start out with until you can get the alien bees.
Just my opinion,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
KevC
Joined Jan 2005
Jan 25, 2005 13:40 |  #3
Thanks! I work right beside a Home Depot, I hope they have them! Do you think worklights + white cloth drooped over them (with enough ventilation of course) would be decent for a softbox for now?
How about those ebay umbrellas?
How about something like this?
http://cgi.ebay.ca …0080&item=38698​63098&rd=1 (external link)
Shipping is huge though... $40!!!
//edit: Is 500W enough?
http://www.homedepot.c​a …c:018980323a3e:​&pc=568200 (external link)
Too much gear...
Longwatcher
Joined Sep 2002
Jan 25, 2005 14:00 as a reply to  @ KevC's post |  #4
Don't droop cloth over the Home Depot lights, they get way too hot for that. You don't want anything flammable actually touching the light or within a few inches in front of it.
If you want to diffuse them, buy some kind of post, pole or frame work that stands by itself and hang the cloth at least 4 inches (preferably 6 or more) away from the light. in a way actually the farther away I think you will actually get better results, but might be completely wrong here.
I just had a thought that may or may not work. If you get a work light like I have with a handle above the light to move it, get a clamp and a squeege (or T-bar) and run the cloth from the squeege in front of the work light. It should work if you have/get a work light like I have.
yes a 500W should work fine for most purposes.
And I can't access ebay from this particular computer.
KevC
Joined Jan 2005
Jan 25, 2005 14:17 |  #5
Oh I was thinking of putting a chair in front of the worklight, and drooping the cloth in front of that. That should be at least a foot away.
Hm. Maybe my next purchase should be a dedicated flash...
Too much gear...
Longwatcher
Joined Sep 2002
Jan 25, 2005 14:34 as a reply to  @ Longwatcher's post |  #6
And I just checked your home depot light
I recommend something a bit more
http://www.lowes.com …oductId=22565-290-HDS1000 (external link)
or
http://www.homedepot.c​a …6:0189803239e1:​&pc=125060 (external link)
But I have the second one and the stand is too short.
Also my primary (before getting my ABs) is a single light with a 6 foot stand. I am beginning to think they don't make them any more.
Sears seems to have a better selection and price.
http://www.sears.com …825000&subcat=W​ork+Lights (external link)
Although a dual light actually diffuses the light better, it is a bit messier to aim them correctly. You want one that will go up at least 6ft (2M) because you usually want your light going down rather then up. I have a single and a double and I like the single better.
And lastly if you want a slightly more professional look, get a can of BBQ black spray paint and go to work on it after of course covering the light and reflector itself (or taking them out like I did).
***Please note, except for a single work light (which is bounced off the ceiling) to give me enough ambient light for focusing, I use Alien Bees as primary lights****
KevC
Joined Jan 2005
Jan 28, 2005 22:50 |  #7
Alright. Bought a 500W light that sits on the floor. GEEZ that's bright. I blinded myself and I only looked at it for a split second (by accident). I think I'm gonna return it, it doesn't have a switch nor an extension cord. (always on, BAM it turns on when you plug it in).
I found one with a short stand and a 250W bulb. Not sure how I'm gonna mount a diffuser on it though. The light is utterly blinding, I'm hoping the 250W would be less harsh lol.
Or maybe I'm just gonna shoot wide open, high ISO, and with a tripod for now lol.
Too much gear...
Longwatcher
Joined Sep 2002
Jan 29, 2005 18:02 as a reply to  @ KevC's post |  #8
You are not supposed to blind yourself, you are supposed to blind the model. ;)
KevC
Joined Jan 2005
Jan 30, 2005 16:45 |  #9
:D
Alright, I've got one of my engineering friends to fab me a t-bar and I'm gonna try your idea. My friend's dad works with clothing so he can probably cut me some white cloth. What material should I use?
Too much gear...
jcost
Joined Dec 2004
Jan 30, 2005 22:15 as a reply to  @ KevC's post |  #10
http://cgi.ebay.com …6&ssPageName=ST​RK:MEWA:IT (external link)
Is this a good light source for a home or small studio. I am just getting started in the studio work, and wanting to get some lights. Is the wattage good enough or is this for small product work. Any response would be great.
John
John in Kentucky
CANON 40D
CANON Digital Rebel 300
battery grip (300)
CANON kit lense
CANON 70-200 2.8 L (love it)
CANON 50mm 1.8
CANON 28-135 IS
TAMRON28-70 2.8
420ex
lowprowe Computer Backpack
2 - 800 Alien bees..
Still Learning and loving every minute of it.
www.myspace.com/johnco​stigan (external link)
Longwatcher
Joined Sep 2002
Jan 31, 2005 07:42 as a reply to  @ KevC's post |  #11
KevC wrote:
:D
I actually have no idea what kind of cloth to use. The best I can recommend is using something like lingere material (not too see through) as it tends to be somewhat shiny and yet will let a lot of the light through, which should give you the diffusion effect you are looking for. You want something you can see shape and shadow through, but not actually be able to see through it.
I don't recommend a heavy canavs as that would be too opaque.
That's my best guess. Me I used a photoflex reflector to bounce the light. It should work though. If I get a chance, maybe I will try it out sometime this week.
keithufp
1 post
Feb 01, 2005 21:56 |  #12
KEVC, for some great ideas on using pvc and inexpensive fabrics to make diffusers, reflectors, gobos etc. go to a site call lightingmagic.com you can purchase the presewn material from this site but I recommend going to a good fabric store you can get the same or better material. For the price this site wants I was kind of disappointed in the fabric quality. He also has a good book that is worth the money on lighting techniques. You can use the halogen lamps but be VERY careful with placement to cloth/fabrics these lights get extremely hot. Good luck, Keithufp
kndreyn
Feb 02, 2005 05:55 as a reply to  @ keithufp's post |  #13
Here is a link to some lessons by Jodie Connor. This has been a great learning tool for me. Lesson 7 shows how to build your own studio lights from a home depot flood light and some foamcore board. I tried it, and it works great. Hope you enjoy as much as I have.
http://www.morguefile.​com/archive/classroom.​php (external link)
7,291 views & 0 likes for this thread, 5 members have posted to it.
2022 guests, 103 members online
