Okay,
I'm just obsessivly thinking, how do custom white balances work. I understand how to set them up and all, however I don't understand how the camera uses the CWB to affect the photo.
Can anybody help me understand this?
fubarhouse Senior Member 480 posts Joined Jun 2008 Location: Canberra, Australia More info | Aug 18, 2008 03:23 | #1 Okay, Canon 40D, 580EXII, BG-E2N, RS-80N3 (Remote), Velbon Vel-flo 5 PH 248 (Tripod), Velbon RUP-43 (Monopod), Hoya CP Filters
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 18, 2008 04:29 | #2 All WB does it say "this is white". Custom white balance just sets the temperature differently from the presets. It's easier to understand once you read a book on color, take a look at the color book in my recommended books thread, linked from the FAQ thread in my sig. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Aug 18, 2008 05:43 | #3 Oh, fair enough. Canon 40D, 580EXII, BG-E2N, RS-80N3 (Remote), Velbon Vel-flo 5 PH 248 (Tripod), Velbon RUP-43 (Monopod), Hoya CP Filters
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 18, 2008 05:58 | #4 CWB is just a single number, a color temperature K that defines the color of the light. If you shoot a gradient as your CWB weird things will happen, and it won't be accurate. What you shoot has to be neutral white or grey. CWB is the same as setting the color temperature by number in your RAW converter. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
rral22 Senior Member 885 posts Likes: 1 Joined Jul 2008 Location: Saskatchewan, Canada More info | Color we see is the result of reflected light from the object. The color of the reflected light is determined by the colors in the spectrum that hit the object.
PhotosGuy Cream of the Crop, R.I.P. More info | Aug 18, 2008 10:10 | #6 So if you use a colored card, that is a card that does not reflect equal RGB values to WB from, you will screw things up royally. Generally, that's true. BUT you can use a colored card to act as a "filter" to skew the colors in the direction that you want them to go in the opposite direction. A magenta card will skew green; Blue will go yellow, etc. FrankC - 20D, RAW, Manual everything...
| Latest registered member was a spammer, and banned as such! 2808 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
