Thread started 18 Aug 2008 (Monday) 08:49
Cokin P System
Alejandro ­ Sandoval
Aug 18, 2008 08:49 |  #1
Hey guys I have a question regarding the Coking P system; I'm about to travel and primarly will be use with ND and GND filters and I have some questions.
I know it's not the best but I hardly use this kinda stuf but
Can you stack filters on the P system
Would it work with the 24-70 and 17-40 ?
Thanks in advance
Twitter (external link)http://www.twitter.com​/Ale_Sando (external link)
Lowner
"I'm the original idiot"
Aug 18, 2008 09:04 |  #2
I use the Cokin "P" system for my grey grads. Yes, it works well on my 24-70L, with its 77mm filter size, on both my 30D (crop body) and Eos-3 (35mm film body).
I don't know what size filter thread you've got on the 17-40 and the wider angle at 17mm might be an issue, you'd need to try one to find out.
The standard "P" series holder will stack three rectangular filters. Although I often end up just hand-holding the filter in front of the lens.
Richard
Bill ­ Pham
Aug 18, 2008 12:35 as a reply to  @ Lowner's post |  #3
i don't seem to have any problem with mine on the 30D and 1D. but then again i haven't been using it that much. i'm planning on trying it out later tonite though on some waterfall shot.
Bill
winning is fun and second is for loser
I got Mitch hook on wide angle :lol::lol:
Gear list
http://billpham.smugmu​g.com/ (external link)
Quad
Joined Nov 2005
Aug 18, 2008 17:35 |  #4
You will get vignetting on the wide on FF I cut the holder down to only hold one filter as the shops did not have the wide holder available. The wide holder does the cutting for you I think. I cannot remember how wide I had to go before it showed but it was probably not just at the extreme end or I would not likely have cut the holder for that only.
I have the 17-40 as well so that was the lens that gave me problems.
JRP2661
Aug 19, 2008 11:28 as a reply to  @ Quad's post |  #5
Cokin has 2 types of "P" filter holders; a standard one that can take 3 filters + a CPL, and a slim model that can only take a single filter. The slim one is designed to eliminate/reduce vignetting on wide angle lenses.
inthedeck
Aug 19, 2008 11:34 |  #6
I'd go with the 'Z' system, since that's what needed for FF's. I have the Z system, and I get a slight issue at 17mm on the 17-40L, but every other lens, is just fine.
MCSquared Photography (external link) on WWW
MCSquared Photography (external link) on Flickr
MCSquared Photography (external link) on IG
My name: Manish.
Colorblinded
Gallery: 18 photos
Aug 19, 2008 11:35 |  #7
inthedeck wrote in post #6137825 (external link)
I'd second this. The Z system will be a better choice for full frame with wider lenses like the 17-40. There are even larger options but the Z should cover you in most cases.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
argyle
Aug 19, 2008 14:32 as a reply to  @ Colorblinded's post |  #8
The P size will vignette unless you cut down the holder, but in doing so, you lose the ability to stack filters unless you handhold. The Z holder will vignette on the 5D/17-40L combo (I had one, sold it for this reason). I switched the holder to the Lee brand...no vignetting on the 5D/17-40L, even with all three filter slots in place (however, you will need the Lee 77mm wide angle adapter ring). For the money (holder is $15 more than the Z-Pro), you'd be better off with the Lee, and you won't have the constraints of the P-system. For the 5D, I'd definitely recommend the larger sized holder, first choice Lee, then Z-Pro.
Colorblinded
Gallery: 18 photos
Aug 19, 2008 15:42 |  #9
Yeah I may have to switch to the Lee holder down the road. After having tried both I noticed the Lee might vignette less but I wasn't sure for certain because I hadn't spent much time with it.
1,542 views & 0 likes for this thread, 8 members have posted to it.
Cokin P System
2733 guests, 147 members online
