primalcarl wrote in post #6139205
Exposing to the right is very popular. But just how far to the right of center should the histogram peaks be? Can anyone link a typical exposed to the right histogram shot?
What am I missing? When I expose a shot using the camera's light meter the histogram peaks are nowhere near the right but the images look fine. Infact I would say the peaks are more to the left of centre.
It helps to understand why this technique is used. The reason is that the 12 bit A/D converter on most cameras uses most of the bits in the highlights. Since you have 4096 gradients of a color to work with the first range of luminance (the highlights/white) takes up 2048 of them, then the next section is 1024, then 512, 256, 128, 64, 32, 16, 8 (shadows/black). This may not be 100% accurate, but it's close. Therefore the more of your picture you get to the right, the more gradients of color you have to work with.
This only works for RAW. When you bring in the picture within the raw converter it typically looks overexposed and what you do is draw down the exposure (normalize it). Theoretically you get a finer picture this way.
There are caveats. The histagram cannot be 100% trusted on the camera because it's sampling just a small JPG image, not the RAW data, to display that histagram so you may not get any highlight burnout warnings on the camera but later find you have overexposed your whites. So don't get right up to the right, just get somewhat close to it.
Furthermore if you have a 14 bit a/d camera (1Ds III, XSi, 40D, 1D III) this becomes less necessary because those cameras have 16,384 gradients which leaves a lot more left over for the shadows. So on a 14 bit camera I wouldn't be so worried about it. Although it's still better to not leave too huge of a gap on the right so that you're not wasting the best part of the sensor capture.
Canon 1Ds III/5D/XSi | 500f/4IS | 200f/2 IS | 135f/2 | 85f/1.2 II | 100-400 | 16-35 II | 24-70f/2.8 | 70-300 DO | Sigma 50f/1.4
