I purchased a used Canon 55-250 IS lens here and it seems to be working well. I have kept the focus switch to Auto. If I accidentally turn the focus ring (instead of the zoom ring, which is what I meant to turn) when the auto mode is engaged, is it causing damage to the lens?
And how about when the end of the lens does not fully recede when I turn it back to 55mm (I don't know how else to describe it), and I put the lens cap on, and the light pressure causes the lens to push back in. Is that something anyone else experiences?
When you twist the lens from 55 to 250mm, is there supposed to be a slight resistance feel to it?
Thanks for the help!
Sandi
