Thread started 19 Aug 2008 (Tuesday) 16:52
Nikon SB-28 or Canon 420EX on S5-IS?
aridan
Gallery: 15 photos
Joined Dec 2003
Aug 19, 2008 16:52 |  #1
Hi all,
This question is for my father who is looking to purchase the Canon S5 IS... He would also like to add a flash. He already has a Nikon SB-28 from a previous Nikon N70 film SLR (yes, he is converting ;)). Can someone tell me if the SB-28 will work on the S5 IS? If not, will a Canon 420EX work?
He is looking for basic automatic TTL functionality.
Thanks in advance. :)
5D Mark III | 135L | 24-70L | 580EXII | Flickr | Instagram (external link)
Permagrin
Aug 19, 2008 16:54 |  #2
I don't believe they are wired the same...and that it could actually be a hazard to the canon camera to use the nikon flash. (I'm not sure about the 420 ex, hopefully someone else will chime in on that).
FlashZebra
This space available
Aug 19, 2008 18:00 |  #3
The SB-28 will work on the S5 IS in manual and "traditional" automaic mode. No ETTL/iTTL control.
Since you already have the SB-28 give it a test drive. If you find it lacking then consider another flash.
Enjoy! Lon
Permagrin
Aug 19, 2008 18:02 as a reply to  @ FlashZebra's post |  #4
could you clarify then (someone told a friend of mine not to use the SB 26 on his M2 or 40D, I can't remember which he was playing with...that it would harm it)...is there a difference then btw. those and the S5? or was the person completely incorrect?
aridan
Gallery: 15 photos
Joined Dec 2003
Aug 20, 2008 15:20 |  #5
FlashZebra wrote in post #6139976 (external link)
Enjoy! Lon
Can you please explain what you meant by "traditional" automatic mode?
TIA :)
FlashZebra
Aug 20, 2008 16:35 |  #6
aridan wrote in post #6146030 (external link)
TIA :)
Long before ETTL or iTTL, flash units had automatic function using a light sensor based in the flash unit itself. The Nikon flash units (including the SB- 28) have retained this flash mode, in addition to integrating newer methodologies.
To use this method you set the ISO on the flash and a select a mode (there are typically a few modes). This mode then recommends a aperture setting for the camera. You the transfer the suggest aperture and selected ISO manually to the camera.
With the exception of the Canon 580EX II, the Canon flash unit of about the last 20 years or so abandoned this very utilitarian mode. But in general the Nikon units have retained this functionality.
Enjoy! Lon
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 20, 2008 17:44 |  #7
Doesn't sound like he wants to fool around with setting ISO, shutter speed and aperture.
The 420EX will work very well on a S5. To get "basic automatic TTL functionality" it will have to be a Canon EX flash or any one of the 3rd party ETTL flashes.
aridan
Gallery: 15 photos
Joined Dec 2003
Aug 20, 2008 18:51 |  #8
msowsun wrote in post #6146827 (external link)
...or any one of the 3rd party ETTL flashes.
Doesn't the SB-28 fall into this category?
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 20, 2008 19:01 |  #9
No, they are an older series of flash. They are dedicated to Nikon only and secondly they don't even do TTL on Nikon's.
They do have a manual or "Auto" mode that can be used with any camera, but you must set everything manually.
aridan
Gallery: 15 photos
Joined Dec 2003
Aug 20, 2008 20:57 |  #10
Great, thanks!
2,023 views & 0 likes for this thread, 4 members have posted to it.
2697 guests, 136 members online
