Thread started 19 Aug 2008 (Tuesday) 21:20
Battery Charging- Am I Being Anal?
yogestee
Aug 19, 2008 21:20 |  #1
Am I being anal?? When I charge my camera batteries I stop charging around 15 mintues after charging is complete.. I keep an eye on the charging process.. Can I damage my batteries if I leave them on charge over night for example??
Jurgen
Riff ­ Raff
Aug 19, 2008 21:35 |  #2
It depends on your charger, but most of them should switch to a trickle charge after they've completed charging. This just keeps the batteries "topped up", since NiMH rechargeables naturally lose power over time. Generally speaking, I keep about twelve AAs in the chargers at all times (i.e. on trickle charge). When I go out on a shoot, I'll rotate those out with the batteries that were in my equipment from the last time I went out. I've been doing this for several years now with no issues.
Shawn McHorse - Shawn.McHorse.com (external link) / AustinRocky.org (external link)
DSLR: 5D Mark III Compact: S100 Flash: 580EX II Bag: Tamrac Rally 5
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS,
50mm f/1.4, 85mm f/1.8
DDCSD
GIVIN' GOOD KARMA
Aug 19, 2008 21:54 |  #3
What battery and charger?
Yes you are being paranoid. ;)
Unless it is a really bad third party charger, it will shut off when full charge is attained and not attempt to charge again. The only real risk you run is an extremely remote chance of fire if there is a catastrophic failure of your charger, battery and circuit breaker/fuse.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
alexg
Aug 19, 2008 22:03 |  #4
I actually just finished a small write up on this :)
http://alexgorbatchev.​com …8/19/powering-your-flash/ (external link)
if you get a good charger, you don't have anything to worry about... better management will probably do more good.
7D, 10-22mm, 35 f1.4L, 24-70mm f2.8L, 50mm 1.8
DDCSD
GIVIN' GOOD KARMA
Aug 19, 2008 22:19 |  #5
OP is asking about his camera batteries.......
Derek
dpds68
Aug 19, 2008 22:23 |  #6
Great write up .
As we type I am staring at 4 AA Recharge on a "El cheapo" Energizer charger but using some Kodak 2500mah that seem to be doing good , but the last time I charged then I left them over night and I found that the did not last as long and were very hot , so I am sitting here waiting to take them out as soon as they finish charging .
Oops sorry now seeing that It was the Camera Batteries not the AA's . :oops:
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
ELT_Photo
Aug 20, 2008 00:41 |  #7
I have left Canon 511a's in the charger (both single and dual slot Canon) for 2+
weeks with zero problems over the past 3 years - same 6 batteries rotated between a 5D and 20D.
Passion - Dedication - Inspiration (and some gear)
SolidxSnake
Aug 20, 2008 01:02 |  #8
DDCSD wrote in post #6141561 (external link)
Still not much of a difference. I've NEVER come to the point where I've overcharged a Li-Ion battery. I think it just trickle-charges them, just the same as NiMH.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
ben_r_
-POTN's Three legged Support-
Aug 20, 2008 08:51 |  #9
I dont think you have to be that paranoid, but I never leave mine on the charger any longer than I can help it. Usually an hour or two tops. Just when I notice its done I take it off.
yogestee
Aug 20, 2008 10:59 as a reply to  @ ben_r_'s post |  #10
Thanks guys,, spose I am being a bit paranoid.. I'm using a Canon CB-2LTE charger for my 350D batteries (Canon) which are over 3 years old and still going strong and a Canon CG-580 for my 20D batteries which are 3rd party batteries..
So far all batteries are good..
Jurgen
Ridebmx
Aug 20, 2008 12:24 as a reply to  @ yogestee's post |  #11
its like any other charger, it charges the battery till its full, then switches over to full charged mode, where it stops charging but just keeps the battery topped off
its like AA batteries and chargers, stops charging once full but keeps them topped off
theres nothing to worry about
Camera gear: 40D, 350D Gripped, AE-1 Program, 70-200mm f/4L, Tokina 12-24mm, Thrifty Fifty 1.8, 75-205 3.5-5.6 macro, 28mm 2.8, 188A, 430EX, Nikon Sb-28, Skyport Triggers
Matthew62024
Aug 20, 2008 15:26 |  #12
I charge mine over night most times. I charge a second battery while I am at work for 8 hours. Never any problems so far.
40D with BG-E2N grip | XTi with BG-E3 grip | 430EX
EF 100-400 F4.5-5.6 L IS | EF 70-200mm f4 L IS | EF-S 17-55mm F2.8 IS | EF-S 18-55mm Kit Lens | EF 50mm f1.8
Wilt
Aug 20, 2008 15:32 |  #13
Ridebmx wrote in post #6144966 (external link)
there are cheap, stupid chargers and there are good, smart chargers
cheap, stupid chargers CAN damage batteries by permitting the 'trickle' to be at too high a level of output.
leaving batteries in a stupid charger for days can damage, where a smart charger is safe even for weeks
1,398 views & 0 likes for this thread, 11 members have posted to it.
2733 guests, 147 members online
