Thread started 21 Aug 2008 (Thursday) 00:22
wein vivitar and sigma = nothing flashes! help
rocker83
Aug 21, 2008 00:22 |  #1
gah so I just got the vivitar 285hv, what a nifty cheap flash I think Ill get good use out of it..
but I also bought a wein peanut slave for it so I could fire it with my sigma ef dg super....
problem..
its not firing...
am I doing something wrong? Does the wein peanut just suck as Ive read abit in these forums?
am I even inserting it correctly? It doesn't really click into the bottom. I just push it in until you can't anymore, not forcefully of course.
help would be great thanks
I shoot Canon, I have some bodies, some lenses,and some lights. Photography is about the image not the L's that get you there. Though, feel free to send me your L's ;)
http://www.michaeljaco​bsphoto.com (external link)http://www.mikejbphoto​graphy.smugmug.com (external link)
SolidxSnake
Aug 21, 2008 00:56 |  #2
you can't shoot the sigma in ETTL, the preflash will throw off the optical slave.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
rocker83
Aug 21, 2008 00:58 |  #3
yup, I know, I shoot manual still nothing.
SolidxSnake
Aug 21, 2008 01:02 |  #4
rocker83 wrote in post #6149470 (external link)
Where are you putting the peanut? From what I remember, the 285HV has a proprietary PC sync port, not a standard PC sync port.
Any pictures of your setup?
edit:
http://strobist.blogsp​ot.com …02/return-of-classic.html (external link)
Are you using the pictured wein peanut?
1) RTFM.
2) Repeat Step 1.
rocker83
Aug 21, 2008 01:12 |  #5
here it is...not firing in all its glory
the peanut is suppose to go there eh?
liquefied
Aug 21, 2008 02:36 |  #6
The peanut requires a higher trigger voltage than the Vivitar provides. It's stupid. And it's recommended to be used on the 285's by Wein. I had the same problem with two brand new 285s and two new peanuts, neither of them would trigger the flashes more than 1-2% of the time. I recommend getting the Cactus V2s wireless triggers on eBay. They cost about $10 more than 2 peanuts and work 99% of the time in any light.
Jim ­ M
Aug 21, 2008 07:57 |  #7
If the Wein peanut has a PC socket on it and the Vivitar has its proprietory receptacle, then you need the short PC cord to go between the peanut and the flash. You should have gotten the PC cord with the flash. I don't know that liquefied isn't right, but I used optical triggers on 283s for years in the pre-digital age. None of them plugged directly into the flash. They all required the short PC cord or attached to the hot shoe. If you have all the parts, it is certainly cheap enough to try.
rocker83
Aug 21, 2008 08:23 |  #8
I did receive a a short pc cord with the flash, I plugged it into the wein and still nothing...
I think its time to take it back, bah :(
gdrMatt
Aug 23, 2008 06:05 |  #9
what shutter speed are you shooting at ?
Canon FTb - Canon FD 54.6mm f1.3 - Vivitar 283 w/Doubler - Argus super seventy-five
Flickr photos (external link)
1,117 views & 0 likes for this thread, 5 members have posted to it.
2833 guests, 132 members online
