I just read this in the review
of the 2.8 lens
I have received some comments on the ISO 12233 resolution chart samples for this lens - some think they are too soft at f/2.8. As I get time, I retest questionable results - Or even buy another copy of the lens to insure accurate but expectable results. I re-tested this lens and the Canon EF 70-200mm f/2.8 L non-IS USM Lens at the 200mm focal length using AF, MF and bracketing - obtained results were identical. The chart is tough on optical performance, and real life images do seem sharper. I use this lens wide open much of the time - the results are quite satisfactory to me.
I guess that sort of explains a little bit, but then at the end he says
Stopping down from f/2.8 to f/4 will show a difference - and will make this lens very close in performance to the remarkable Canon EF 70-200mm f/4 L IS USM Lens at the same aperture.
by "very close" is he implying that the f2.8 will not be able to achieve the great image quality of the f4?
