Thread started 21 Aug 2008 (Thursday) 09:48
Good article on AF focus for portrait shots
sinitry23
Aug 21, 2008 09:48 |  #1
http://visual-vacations.com …focus-recompose_sucks.htm (external link)
http://www.william-chang.com/ (external link)
canonrebel
Aug 21, 2008 10:46 |  #2
Excellent advice, and probably something a lot of people dont actually realise, myself included.
You learn something new every day, as they say.
Steve.
Riff ­ Raff
Aug 21, 2008 10:50 |  #3
Yep. Am very glad I can actually use all the focus points on my 40D now (i.e. I couldn't before with the Rebel XTi since the non-cross sensors would frequently fail to focus). It can be limiting sometimes as far as composition, trying to always align an eye with one of the nine focus points, but the shot needs to be in focus first off...
Shawn McHorse - Shawn.McHorse.com (external link) / AustinRocky.org (external link)
DSLR: 5D Mark III Compact: S100 Flash: 580EX II Bag: Tamrac Rally 5
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS,
50mm f/1.4, 85mm f/1.8
tim
Light Bringer
Aug 21, 2008 17:51 |  #4
Hey, I didn't realise the 40D had all cross type focus sensors, that's handy! Because of this I wasn't using off centre points much.
elysium
"full of stupid banter"
Location: Harrow/London/UK/GB/That Part Of The World/Next To France
Aug 22, 2008 02:44 |  #5
Simple write up. Makes more sense and realise what my problem was.
Everyday, a programmer finds a way of creating an idiotproof program. Everyday, the universe spits out another idiot.....So far, the universe if winning
Greg_C
Gallery: 10 photos
Joined Nov 2005
Aug 22, 2008 07:05 |  #6
Another benefit of of using other focus points is it forces you to look at the composition more. My composition improved a great deal when I started using the off-centre focus points.
Greg
Blog (external link) | Photogallery (external link) | 1DmkIV + other stuff
Sanity is a madness put to good use.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Aug 22, 2008 07:57 |  #7
For those who haven't discovered the feature yet, I use C.Fn-13 (1) to put the focus points on my joystick (multi controller) which makes it easy to switch when things are moving fast or other situations where I need an off-center point.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Aug 22, 2008 08:00 |  #8
This has been discussed several times before.
The article makes some valid points, and also some not so valid ones.
A change of only 2 inches will not effect most shots, unless your shooting with a 50 1.2 wide open.
So long and thanks for all the flash
snuttebuff
Aug 22, 2008 08:46 as a reply to  @ Moppie's post |  #9
Interesting read!
How do you experienced guys deal with this problem?
Use the less sensitive outer focusing points? MF?
400D | Tamron 17-50 | Canon 55-250 IS | 50mm 1.8
Riff ­ Raff
Aug 22, 2008 10:35 |  #10
Moppie wrote in post #6155390 (external link)
I'm frequently shooting a 85mm f/1.8 at distances of around eight feet on a crop body. According to the calculator (external link) that gives me a depth of field of +/- one inch. Focus inaccuracies of a couple of inches can be very significant, even if you're not using a f/1.2 lens.
snuttebuff wrote in post #6155614 (external link)
One of my favorite things about the 40D is that the outer focusing points are cross sensors also, so any of them work well.
yogestee
Aug 22, 2008 10:38 |  #11
Interesting read!
When I need to critically focus I manually focus and ignore all focus points..
Jurgen
Tixeon
Joined Oct 2004
Aug 22, 2008 15:22 |  #12
As was noted in the article concerning Focus/Recompose - the greater the distance to the subject the less problem this is. It's also less of a problem with a longer focal length lens when making a normally composed portrait - not extreme closeup.
I personally found Focus/Recompose more of a problem when using a tripod. I prefer to hand hold when possible & I do Focus/Recompose but I adjust my distance slightly by leaning back/forward very slightly until the image visually looks in focus & I have very little problems doing so. I learned this technique long ago in macro work. Also what yogestee said.
Tim
______
Any cat owner will tell you -- no one really owns a cat...
1,582 views & 0 likes for this thread, 11 members have posted to it.
2646 guests, 155 members online
