All recommendations are welcome.
As long as it can contain a 5D mounted with 70-200 f/2.8 IS with hood reverse mounted, 24-70L with hood reverse mounted and 85mm/1.8.
Small or large size does not matter as long as it can fit them all.
Thank you.
Pasukun Goldmember 1,388 posts Joined Feb 2007 Location: US More info | Aug 21, 2008 14:33 | #1 All recommendations are welcome. "the things we touch have no permanence.. as there is nothing we can hold onto in this world.. only by letting it go can we truly possess what is real.."
GWilliams Member 73 posts Joined Oct 2005 Location: Warrington or Lincoln, UK More info | Aug 21, 2008 14:47 | #2 Anything in particular you want to use it for? -Gaz-
SuzyView Cream of the Crop More info | Aug 21, 2008 17:34 | #3 I just bought a Kata 467 for $69 and it's a beautiful backpack. I put the 5D with 24-70 attached in the bottom camera compartment with the 85 on the side and then the 70-200 2.8 IS in the top compartment with all the other stuff I need to bring. It's a small backpack but very sturdy. Suzie - Still Speaking Canonese!
SYS Cream of the Crop More info | Aug 22, 2008 10:22 | #4 Any of Kata backpacks is great. I just completed my travel across South Korea for a month with my Kata R-103 (with laptop compartment), and it was just perfect. Kata R-103 is airline compliant for carry-on, so I had all my gears with me.
Aug 22, 2008 10:44 | #5 Great! Thanks guys. "the things we touch have no permanence.. as there is nothing we can hold onto in this world.. only by letting it go can we truly possess what is real.."
fishfoto -Krazy Glue- 840 posts Likes: 1 Joined Mar 2008 Location: Live: HVN Work: The World More info | Aug 25, 2008 13:30 | #6 I always strongly advise against traveling with your lens attached to the body,but if you must travel that way, check out the Mountainsmith Quantum. - Fish
xMClass Goldmember 2,203 posts Joined Jun 2008 Location: California More info | Aug 31, 2008 00:47 | #8 Might want to consider a Canon 200EG. I use it along with a gripped 30D I can carry two of my white L's and my 17-40 L or 24-105 L, with lots of extra space, for a flash and other accessories. -Mikey
fishfoto -Krazy Glue- 840 posts Likes: 1 Joined Mar 2008 Location: Live: HVN Work: The World More info | Aug 31, 2008 07:31 | #9 I have found the Canon 200EG to come apart at the seems and have serious zipper problems. I had purchased one , used it with two 1D bodies, a small selection of lenses and a 12" PowerBook , with basic accessories. The strap width made it slightly uncomfortable when loaded, but not bad for the intended purpose. - Fish
Sports_Dude Goldmember 1,111 posts Likes: 4 Joined Feb 2008 Location: California More info | Aug 31, 2008 15:44 | #10 fishfoto wrote in post #6175246 I always strongly advise against traveling with your lens attached to the body Why is this bad? Just curious. Sports_Dude
Sports_Dude Goldmember 1,111 posts Likes: 4 Joined Feb 2008 Location: California More info | Aug 31, 2008 15:49 | #11 fishfoto wrote in post #6213221 I have found the Canon 200EG to come apart at the seems and have serious zipper problems. I had purchased one , used it with two 1D bodies, a small selection of lenses and a 12" PowerBook , with basic accessories. The strap width made it slightly uncomfortable when loaded, but not bad for the intended purpose. In the end though, after 2 weeks and 8 or 9 flights it really wasn't holding up at all. I've been using the 200EG since January '08 without any issues. I usually carry 40D with 70-200 and 40D with 17-55 or a 40D body and lens with 2 580 Flashes. For under $30, this backpack is great. Sports_Dude
fishfoto -Krazy Glue- 840 posts Likes: 1 Joined Mar 2008 Location: Live: HVN Work: The World More info | Aug 31, 2008 19:38 | #12 Sports_Dude wrote in post #6214976 Why is this bad? Just curious. Most all camera/lens manufacturers will suggest this as well. As a bag is moved around it has 'inward pressure' should you drop your bag, or should your bag sustain impact, you have a high likely hood of damaging both your camera and lens at the mounts. The lens and body can absorb and disperse the pressure better when not connected. - Fish
Sports_Dude Goldmember 1,111 posts Likes: 4 Joined Feb 2008 Location: California More info | Aug 31, 2008 20:49 | #13 fishfoto wrote in post #6216101 Most all camera/lens manufacturers will suggest this as well. As a bag is moved around it has 'inward pressure' should you drop your bag, or should your bag sustain impact, you have a high likely hood of damaging both your camera and lens at the mounts. The lens and body can absorb and disperse the pressure better when not connected. I know many (MANY) photogs who have had gear damaged that would have otherwise been OK because they had a lens attached to a body when a bag was dropped or knocked over hard. You can also save space and pack more effectively with them separately. I spent well over a decade as a news photographer covering breaking news throughout the United States, and around The World, and I have never been in a situation where I thought "if only I was able to take my backpack off and take out my body attached to the lens I would have captured the moment." Pack them apart save yourself the repair expense bill. It may not happen today or next month, but bags to get nailed pretty hard sometimes. Thanks for the detailed response. Sports_Dude
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Aug 31, 2008 21:13 | #14 I just bought a Fastpack 200 and my 40D and 70-200f4 IS, with hood reversed fits with lots of room to spare. This night work with the 2.8, Bohdan - I may be, and probably am, completely wrong.
fura.s28 Member 95 posts Likes: 1 Joined Jun 2008 Location: UK <---> HK More info | Sep 01, 2008 02:08 | #15 I used to have Lowepro Mini Trekker, which fit my need perfectly. 5DIII
| Latest registered member is SteveeY 1253 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
