Hey all. I was having troubles a while back with an old Kodak Six-20 foldout and light leakage, but that seems to be mostly fixed. I got a roll back with no apparent leakage, but I just got the next one back, and it looks like I may have some new problems, and I was wondering if anyone would have any idea as to their causes. I've attached two images from the latest roll. One is my sister, shot with window light. In this one, there's that great big artifact-looking thing marring the image. My suspicion here is that this is flare from the window, as the same pattern appears on another image shot more away from the window, but to a lesser extent. There also appears to be some light leakage in the lower right of the frame, which I think may be due to the fact that the film didn't wind completely tight on the spool, and some of it may have bulged out and had some light leak in past the backing paper. Or perhaps it's just another pinprick on the bellows?
On the other attached image, shot in broad daylight, there's a more troublesome white blotch, which I'm finding especially worrisome because you can actually see one of the numbers from the backing paper. I'm afraid that may mean that there's light leaking in from the back, unless there's some other way that the backing paper could have gotten imprinted onto the film.
On a final note, I also have a shot on the roll that was done at night, with long exposure and a strobe, which has no apparent leakage at all: likely because there wasn't enough light around to penetrate the bellows and/or camera. Also, I should probably note that I did do some nasty underexposure thanks to metering errors, and so had to have this film pushed a stop when they developed it, and I'm guessing that probably accentuated any defects of the camera at play. And, of course, C&C welcome on the portrait welcome (this wasn't really my favorite of them at all, but I uploaded it to make sure to show the light leakage issue)
It's still kind of impressive how well it works out, though, considering that it's basically a plastic bubble...
