I shoot a 5D and have set the custom function to 2nd curtain sync. I have AB strobes and sync them with PW +2s. On a multi second shutter the flash fires when the shutter is pressed.
Am I not doing something right or is this not possible?
ean36 Senior Member 625 posts Joined Jun 2006 Location: West Palm Beach, Florida More info | Aug 22, 2008 07:48 | #1 I shoot a 5D and have set the custom function to 2nd curtain sync. I have AB strobes and sync them with PW +2s. On a multi second shutter the flash fires when the shutter is pressed. be safe and well. George
jcolman Goldmember More info | Aug 22, 2008 08:40 | #2 Mine does the same thing. I think I recall reading somewhere that it's not possible to use second curtain sync on the 5D with off camera flash fired via PW's.
Thanks for the reply. Will it work with your 1D? be safe and well. George
jcolman Goldmember More info | Aug 22, 2008 10:23 | #4 ean36 wrote in post #6155788 Thanks for the reply. Will it work with your 1D? Haven't tried it yet with the 1D. I'll give it a shot next time I pull out my gear.
JakPot Senior Member 826 posts Joined Mar 2006 Location: 80203 More info | Yeah, I was under the understanding that 2nd curtain sync only works with ETTL, but let's wait for someone with more knowledge to be sure.
2nd curtain & high speed sync are both lost when you go off-camera with triggers such as PWs, Skyports, ebay triggers etc. However, there is a way of doing this with Skyports so it should work with PWs as well. What you need to do is put a dedicated Canon flash on your camera and either point it away from the subject or use it's lowest power setting so it doesn't effect your subject. You use an optical flash trigger and place the sensor over the flash head and connect it to your transmitter. By setting the flash on the camera to 2nd curtain sync it "fools" your camera into thinking your using that flash instead of the off-camera flashes. Once the on-camera flash goes off it triggers the transmitter via the optical trigger which then triggers all off-camera flashes. This also works for high speed sync with a limitation on the power output you have to use with the off-camera flashes. Here's a link to where I learned about this working for high speed sync: http://www.flickr.com …?search=high+speed+hacked Ray
tadrscin, thanks. be safe and well. George
bimmerteck Member 32 posts Joined May 2008 Location: Nashville, TN More info | Aug 22, 2008 10:56 | #8 I have been reading about the PW Multi-Max and it advertises rear curtain sync, So possibly upgrading to a Multi-max (master) transmitter and using it to control the Plus IIs would give you this ability? _______________
Well I read up on the Multimax since a couple of people have mentioned them for use with other things I want to do. I had originally thought that if I bought PWs and wanted a Multimax, I'd have to buy all Multimax units which would be too costly. After reading about them it looks like I could buy just one for my primary camera and use Plus IIs for the rest. Not only does the Multimax have 2nd curtain sync, but it sounds like it will allow me to fire a handheld camera, a remote camera and off-camera flashes all in sync. Ray
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Aug 22, 2008 22:43 | #10 tadrscin wrote in post #6156379 2nd curtain & high speed sync are both lost when you go off-camera with triggers such as PWs, Skyports, ebay triggers etc. However, there is a way of doing this with Skyports so it should work with PWs as well. What you need to do is put a dedicated Canon flash on your camera and either point it away from the subject or use it's lowest power setting so it doesn't effect your subject. You use an optical flash trigger and place the sensor over the flash head and connect it to your transmitter. By setting the flash on the camera to 2nd curtain sync it "fools" your camera into thinking your using that flash instead of the off-camera flashes. Once the on-camera flash goes off it triggers the transmitter via the optical trigger which then triggers all off-camera flashes. This also works for high speed sync with a limitation on the power output you have to use with the off-camera flashes. Here's a link to where I learned about this working for high speed sync: http://www.flickr.com …?search=high+speed+hacked Just took a look at that link you provided and I have to say, Rafa came up with a very ingenious yet simple way to use HSS with just about any flash or strobe which has sufficient flash duration to make that possible. I just tried it using a home-made optical trigger, a pair of PW units and two flashes, and high-speed syncing with a PW-triggered flash worked like a charm. Thanks for sharing the link. ...Leo
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Aug 22, 2008 22:48 | #11 ean36 wrote in post #6156472 tadrscin, thanks. I'm going to try the STE-2 to trigger a 580 that will optically trigger the AB strobe. Just wanted to mention that if you are going to do this, you'll need to make sure that the AB strobe cannot directly or indirectly "see" the IR signal from the ST-E2, otherwise, the IR signal will trigger the AB strobe prematurely. if all you're looking to do is sync the AB strobe with the camera using the ST-E2, all you need to do is either attach the ST-E2 to the camera PC port or use a piece of tape to cover up the 4 dedicated pins of the hotshoe. Using the ST-E2 this way, there will be no need for an intermediate 580EX to trigger the AB strobe unless you wanted the 580EX to provide lighting, too. ...Leo
Aug 23, 2008 11:49 | #12 PacAce wrote in post #6160407 Just took a look at that link you provided and I have to say, Rafa came up with a very ingenious yet simple way to use HSS with just about any flash or strobe which has sufficient flash duration to make that possible. I just tried it using a home-made optical trigger, a pair of PW units and two flashes, and high-speed syncing with a PW-triggered flash worked like a charm. Thanks for sharing the link. ![]() Yeah that's a pretty sweet trick. When it comes to DIY and clever workarounds, the Strobist folks are great. Ray
PictureDisk Member 72 posts Joined Dec 2007 Location: Boston More info | Permanent banBump http://www.flickr.com/photos/picturedisk/
AntonLargiader Goldmember More info | Jul 11, 2011 07:15 | #14 tadrscin wrote in post #6156379 2nd curtain & high speed sync are both lost when you go off-camera with triggers such as PWs, Skyports, ebay triggers etc. I think that's simply not true as a general statement, because the PW TT1/TT5 definitely support 2CS and HSS. The OP is using older PWs which may not support these features. PictureDisk wrote in post #12735295 ... Has anybody else figured out a direct way to accomplish off-camera second curtain sync on a Canon DSLR body, using radio triggers?? If the camera body works with the TT1/TT5 (I believe the 60D doesn't) then you have a plug and play solution right there. No tricks, no nothing. That product does what you ask. Image editing and C&C always OK
Hoppy1 Senior Member 841 posts Joined Sep 2005 Location: Midlands, UK More info | Jul 11, 2011 09:14 | #15 Canon's second-curtain sync trigger signal comes from the E-TTL contacts, not the central firing pin, so you need some way of accessing that. 5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
| Latest registered member was a spammer, and banned as such! 2599 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
