Thread started 22 Aug 2008 (Friday) 12:08
My Xsi is back focusing in low light conditions, is this normal?
garycoleman
Aug 22, 2008 12:08 |  #1
Yesterday I was shooting in a room that had low/yellowish lighting and found my shots to be out of focus. So I did the battery test in the low lighted room and I can confirm it is back focusing.
However when I took shots and did the battery test in a brightly lighted room that had whitish light, the focus was spot on.
Is this normal? I didn't feel like the lighting was that low. It was just sort of yellowish and not as bright because of the incadescent bulb used in that room.
Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
SolidxSnake
Aug 22, 2008 12:09 |  #2
What lens?
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
garycoleman
Aug 22, 2008 12:16 |  #3
SolidxSnake wrote in post #6156888 (external link)
What lens?
the EF-S 18-55 IS kit lens that came with my XSi
SolidxSnake
Aug 22, 2008 12:22 |  #4
I don't think that lens is the best focusing lens out there (it's a f/3.5 lens, the sensors could really benefit from an f/2.8 or wider lens).
1) RTFM.
2) Repeat Step 1.
garycoleman
Aug 22, 2008 16:23 |  #5
I did some more battery tests.
1. With the focal length at 18mm, max aperture, yellow/warm/low light, batteries 2ft from the lens : It will back focus.
2. With the focal length at 18mm, max aperture, yellow/warm/low light, batteries 1ft from the lens: It will focus spot on.
So why is it back focusing in case #1 ? I made sure to space the batteries far enough so the center auto focus point won't pick up the adjacent batteries.
picturecrazy
soft-hearted weenie-boy
Aug 22, 2008 16:28 |  #6
well gary, willis says, "say what? let's see some sample images!"
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
wimg
Aug 22, 2008 16:36 |  #7
Hi Gary,
Did you do this test on a tripod or handheld? Did you take into account, regarding the spacing of the batteries, that the actual focus point is 3X bigger in all directions than the AF light in the view finder indicates? What were your shutter speeds?
Kind regards, Wim
garycoleman
Aug 22, 2008 16:46 |  #8
picturecrazy wrote in post #6158331 (external link)
I did the tests before I went to work an hour ago. I will post them when I get home.
wimg wrote in post #6158373 (external link)
Hi Gary,
Kind regards, Wim
I used neither. I let the camera sit on top of the table along with the batteries. I don't remember the shutter speeds because I used Av mode to set the aperture at the lowest setting to get the shallowest DoF, so the camera took care of the shutter speeds for me.
JeffreyG
Gallery: 42 photos
Aug 22, 2008 19:31 |  #9
What chu talkin' bout Willis?
I pity the fool with a back focussin' XSi!
garycoleman
Aug 23, 2008 12:23 |  #10
I did some tests again today. I used 3 batteries in the for the center focus to make sure AF won't stray to somewhere else. It seems focus on the center batteries again, but there is still slight back focus.
Here is the testing configuration
As you can see here the center batteries are in focus now. However,the rear battery is more focused than the front battery. Aren't they supposedly to be equally out of focus?
I took 10 shots and that's how all they look like. I manually adjusted the camera out of focus and then let the camera auto focus for every shot. So does anyone think this slight back focus is ok?
SolidxSnake
Aug 23, 2008 12:26 |  #11
garycoleman wrote in post #6162733 (external link)
As you can see here the center batteries are in focus now. But the rear battery is more focused than the front battery. Aren't they supposedly to be equally out of focus?
No, as a rule of thumb, the focal point is 1/3 into the DoF. Which means, that there will be more DoF behind the subject instead of in front of it.
BTW, it looks just fine to me. No back/front focus issues that my eye can see. Also, if it hasn't been mentioned yet, the lens could be backfocusing (if there is a focus problem anyway) and not the camera.
1) RTFM.
2) Repeat Step 1.
j0sh_dc5
Aug 23, 2008 12:27 |  #12
battery in the back looks like it has more light.
http://forums.clubrsx.​com …?p=19745755&pos​tcount=143 (external link)
garycoleman
Aug 23, 2008 12:41 |  #13
SolidxSnake wrote in post #6162752 (external link)
thanks, i guess eveything is fine after all :D
I was just trying to find any flaws with my camera before the 14 day return/exchange policy is up:oops:
number ­ six
fully entitled to be jealous
Aug 23, 2008 13:18 |  #14
garycoleman wrote in post #6162799 (external link)
Looks like it to me, too. Enjoy your new Xsi...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
wimg
Aug 23, 2008 15:51 |  #15
Hi Gary,
As others indicated, this is perfect focus. Back focus and/or front focus means that the actual focusing point is not in focus, IOW, if you focused on the middle battery, and it would not be in focus, but either the batteries closer towards you (front focus), or the batteries further away from you (back focus), you would have a problem.
I am glad everything is ok after all.
Kind regards, Wim
3,687 views & 0 likes for this thread, 9 members have posted to it and it is followed by 2 members.
1448 guests, 149 members online
