Thread started 22 Aug 2008 (Friday) 15:39
Is this lens any good?
primosanchez
Aug 22, 2008 15:39 |  #1
I just discovered that I had it, don't know much about lenses.
Here's the info I found:
Canon Lens FD 50mm 1:1.8 S.C.
Is it any good and will it work on my XSi?
DreDaze
Gallery: 49 photos
Aug 22, 2008 15:43 |  #2
bottom line no...you need an ef or ef-s mount...FD is for older film cameras
you can get an adapter...but i doubt it's worth it
Andre or Dre
gear list
Instagram (external link)
wimg
Aug 22, 2008 15:44 |  #3
primosanchez wrote in post #6158074 (external link)
Yes, it is good, and no, unfortunately it won't work on your XSi.
I'd suggest you get the Canon EF 50 F/1.8 II, which is about $80, and although much more cheaply made, it has the same optics with slightly better coatings.
If you'd want something as sturdy and as well made, consider buying a used 50 F/1.8 with metal bayonet, the Mk I, probably sells around $150 in good working order, provided you can find one.
Kind regards, Wim
901 views & 0 likes for this thread, 3 members have posted to it.
993 guests, 184 members online
