Thread started 22 Aug 2008 (Friday) 21:26
monopod---40d and 100-400
tomdlgns
Aug 22, 2008 21:26 |  #1
i need a monopod, what is a good one to get?
i dont need to stick with the canon brand, but what do you guys think of this one?
http://www.amazon.com …ics&qid=1219458​185&sr=1-1 (external link)
what would i need if i wanted to mount my camera vertically on a monopod?
none
Ultimate ­ CC
Aug 22, 2008 21:31 |  #2
i would go with a feisol, www.feisol.com (external link), they are awesome and work great with that combo...i had that canon one and it really couldn't handle it...
My Gear And For Sale Items
www.danhonovich.com (external link)
www.danhonovich.blogsp​ot.com (external link)
Anke
Aug 22, 2008 21:32 |  #3
Manfrotto Digi's are nice. I have one. For vertical shooting you just use a ball head or other type of head that can angle to 90 degrees.
Anke
tomdlgns
Aug 22, 2008 21:33 |  #4
Ultimate CC wrote in post #6159975 (external link)
did the canon one feel crappy compared to other brands?
thanks!
none
tomdlgns
Aug 22, 2008 21:37 |  #5
this might sound somewhat confusing, but what holds the camera in place when you have it on a ball swivel?
the only thing it is connected to is a nut. with my tripod and my 70-200 4, when i had it, the camera started to lean forward when i angled it 90 degrees, since there was nothing to hold it from going down...i tightened the nut more, and it seemed to stay in place, but i had it pretty tight, and i didn't feel comfortable tightening it that much.
none
illusionest
5D MkII? CHECK!
Aug 22, 2008 21:37 |  #6
manfrotto 681 (black or silver, doesnt matter).
i have it, love it, does the job, and heavy duty, and most important of all, not overpriced.
edit again: you want something thats reliable; so dont get a cheap one.
edit: you need some kind of head (or maybe you dont, depends how you like it). you attach that head to the monopod (or tripod) and maneuver the head for position / angle adjustment. There's some type of plate included with heads. You dont need a head for monopods, since, you can move it in any direction anyway! :D
if you want it to tilt - then manfrotto 234RC - simple and does the job.
(btw i have all the stuff i said in this post)
Matthew Law
Gallery (external link) | My Gear | IG: @matthew.law (external link)
Anke
Aug 22, 2008 21:39 |  #7
tomdlgns wrote in post #6160011 (external link)
Not sure I understand your question, do you mean the camera creeps when on a ball head? Can you rephrase please?
Anke
tomdlgns
Aug 22, 2008 21:45 |  #8
Anke wrote in post #6160026 (external link)
yes...
my tripod now, has the nut for the camera and a small plastic nub. the nub is an extra piece of plastic that fit into my old camcorder, i believe it is universal.
this way, when the plastic nub and the nut were in place, there was no way for the camera to lose its position regardless if it were flat or vertical.
my 40d doesn't have this extra spot for the nub to fit in, i dont know any DSLRs that do.
the nub is spring loaded, so the weight of the 40d pushes the nub into the tripod head.
canon grips have the same concept designed, let me find a pic to elaborate...
none
tomdlgns
Aug 22, 2008 21:46 |  #9
IMAGE: http://www.bhphotovideo.com/images/largeimages/521093.jpg
look at the right side of the grip, there is a chrome ball or metal piece...that fits into the bottom of the camera so it has something to grab onto and cant be rotated...
does that make sense?
none
Anke
Aug 22, 2008 21:50 |  #10
tomdlgns wrote in post #6160068 (external link)
yes...
A ball head won't have this little "nub", it's just the screw thread. Manfrotto ball heads are so tough that they hold my 1D Mark III with 100-400 on it at all angles with no slippage.
This is the ball head I have: http://www.dpfphotocen​ter.com …catalog/images/​488RC2.jpg (external link)
Anke
crn3371
Aug 23, 2008 01:15 |  #11
The Manfrotto 679,680,and 681 pods are all good, and all relatively cheap. I use the 679B with the 3232 swivel head on my 100-400. With that lens, you're going to want to mount the pod to the tripod collar on the lens, not on the camera. That will give you better stability, and the collar will allow you to rotate the camera to portrait orientation.
xn2b8r
Aug 23, 2008 01:27 |  #12
Count me as another vote for the Feisol. It's carbon fiber, unbelievably lightweight and very solid. Better yet, it's a steal for the price.
--Jeff
1D Mark III :: 5D Classic w/BG-E4 :: EF 24-70 f/2.8L :: EF 135 f/2L :: EF-S 17-55 f/2.8 IS :: EF 70-200 f/2.8L IS II :: 580EX II (x4) :: ST-E2 :: Gitzo GT2330, GT1541T :: Markins M10 :: Feisol CF mono
tomdlgns
Aug 23, 2008 01:43 |  #13
crn3371 wrote in post #6161023 (external link)
correct, with the 100-400 i would use the tripod collar...that was my intention the entire time, however, i didnt realize that i could just loosen the collar and rotate. ;)
thanks guys
none
mrklaw
Aug 23, 2008 03:16 as a reply to  @ tomdlgns's post |  #14
I just bought the manfrotto 680b and a 234RC tilt head. I previously had a slik monopod and a ballhead. The ballhead gives you too much movement, when for a monopod I really want stability and stiffness.
The 234RC lets me tilt it in one direction only - i.e up and down. so it won't be wobbling about at the top of the monopod. Then when I use the 100-400 on its collar I can loosen the collar to flip between portrait and landscape orientation.
I'd get a head with an RC quick release plate, then you can get a ballhead for your tripod that also uses the same one, and just leave a plate on your camera and one on the 100-400 tripod collar so you can switch around between monopod/tripod/camera/​collar quickly and easily.
no dear, it didn't cost much at all
my stuff
Zebceponaf
Aug 23, 2008 03:25 |  #15
ok I just watched the little intro clip and all I have to say is: LOL. That looks awkard as hell, let alone completely absurd.
My Site (external link)
gear stuff here
3,987 views & 0 likes for this thread, 17 members have posted to it.
2625 guests, 152 members online
