Thread started 23 Aug 2008 (Saturday) 03:08
Old flash with new body
NicD
Aug 23, 2008 03:08 |  #1
Hi all, just brought an old flash from my eos 1000, the flash is a 200E, will this work on my XTI?
if not, whys that?
cheers, Nic
Lotto
Aug 23, 2008 03:17 |  #2
That's a old TLL flash, will not work on the XTi. You need a ETTL flash like the EX series.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
NicD
Aug 23, 2008 03:25 |  #3
Lotto wrote in post #6161274 (external link)
ok, thankyou
Wilt
Aug 23, 2008 07:19 |  #4
To add to Lon's statement...
For camera-controlled flash exposure automation, you need an 'ETTL' compatible flash -- which a TTL-compatible flash is not
Or for flash automation controlled by the flash, you can you a flash with an 'Auto' mode at a built in photosensor in the flash.
Or for flash with manual exposure control only, you can us a flash with a Manual mode only.
In using any 'older' flash unit, you will need to use flash units which have a synch voltage below 6v (many older flashes have synch voltage of hundreds of volts!) for Canon cameras preceding the 20D/350D. Later Canon bodies are fine with 250v synch voltage flash units.
844 views & 0 likes for this thread, 3 members have posted to it.
2833 guests, 132 members online
