Thread started 24 Aug 2008 (Sunday) 04:35
B+W 72mm 72 mm MRC CPL Circular Polarizer Filter
MaDProFF
Aug 24, 2008 04:35 |  #1
I tried to find some info on this filter, can someone please tell me can you stack these filters with other ones of the same thread?
B+W 72mm 72 mm MRC CPL Circular Polarizer Filter-
Photographic Images on Brett Butler (external link) px500 (external link) & Flickr (external link) Some Canon Bodies , few blackish lenses, A dam heavy black one, couple dirty white ones, a 3 legged walking stick, a mono walking stick, and a bag full of rubbish :oops:
And Still Learning all walks of life, & most of all Photography.
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Aug 24, 2008 05:10 |  #2
On a side note... Why stack 'em? If you have a UV and CPL take the UV off and put the CPL on as the UV is pretty useless for protection if you have the CPL on top.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
argyle
Aug 24, 2008 07:04 |  #3
MaDProFF wrote in post #6166765 (external link)
Shouldn't be a problem, as long as its not a slim filter (let me clarify that...you can stack a slim B+W CPL filter provided its the outermost filter in the stack due to it not having any front threads). I'm not aware of any issues that would prevent stacking, other than a manufacturing defect, even with a different brand of filter...threads sizes are pretty much standard across the board. To be sure, try it with one of your UV filters (assuming that you have one).
jdizzle
Darth Noink
Aug 24, 2008 07:47 |  #4
I've actually stacked an ND and CPL together and no problems. It may not be something you would do everyday but, alot of the famous landscape photogs do this all the time for a certain effect.
JimAskew
Gallery: 6 photos
Aug 24, 2008 07:59 as a reply to  @ jdizzle's post |  #5
I have B+W 77MM UVA and a CP (slim version)...both are brass construction. When I stacked them I could not get them seperated again. So, I ordered a filter wrench from B+H and that solved the problem. I think the problem was I could not get a good grip on the slim CP.
Lesson learned...don't stack unless you have a filter wrench in your bag. Now when I use my CP I remove the UVA first abd store it in the CP case.
Jim -- I keep the Leica D-Lux 7 in the Glove Box just in case!
7D, G5X, 10-22MM EF-S, 17-55MM f/2.8 EF-S IS, 24-105MM f/4 EF L, Leica D-Lux 7
sapearl
Gallery: 243 photos
Aug 24, 2008 08:46 |  #6
You could certainly stack filters - I don't myself - so long as you don't vignette, and as Jim points you have filter wrench just in case. But keep in mind, the more glass you add on top of your lens, the greater the possibility for introducing a random reflection, flare, or even aberration.
I use only the filter I need. Hey Jim, how do I get that 20% IHOP discount? :D- Stu
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
2,204 views & 0 likes for this thread, 6 members have posted to it.
2627 guests, 153 members online
