Thread started 28 Jan 2005 (Friday) 14:57
IR problem
Pamela107
Joined Nov 2003
Jan 28, 2005 14:57 |  #1
Finally I have a IR filter!
I took some photos today, and when I try to use photoshop element or Photoshop 5.LE
I find an area that lets me change only part of the red/blue channels.
But not they way it is described. Is the technique a little bit different because Im using a Imac computer, or do I not have the right software. (I hope not).
Thankyou
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
www.exposedimages.net (external link)
ekrunaj
Joined Feb 2004
Jan 30, 2005 00:14 |  #2
It's not specified what you are trying to do with the Infrared photos in PhotoShop. Try the channel mixer. Image> Adjust> Channel Mixer. RGB sliders will be available to you. There is also a Constant slider; use it sparingly. If you are converting to black and white you should still use the Channel Mixer, but check mark the Monochrome box and then use the sliders to get a black and white image to your liking.
Pamela107
Joined Nov 2003
Jan 30, 2005 06:09 |  #3
Thankyou for the reply
The problem I have is I can t find anything named channel mixer. When I go to Image>Adjust>
the next choices are equalize, gradient map, invert,posterize, Threshold.
What I tried was enhance>adjust brightness/contrast>levels> then a level box shows channels RGB, red,blue, green. I dont see a choice for boost.
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
ekrunaj
Joined Feb 2004
Jan 30, 2005 09:41 as a reply to  @ Pamela107's post |  #4
I suspect that you only tried looking for the Channel Mixer in Elements, which does not include it. Channel Mixer was new to PhotoShop 5, so it should be included in 5 LE. If there is any question, the Constant slider lightens or darkens all the channels across the board. I am using a "Bondi Blue" iMac, running OS 9.1 with PhotoShop 5.5.
Pamela107
Joined Nov 2003
Feb 01, 2005 00:51 |  #5
I will check the Photoshop 5.0LE program and let you know
Thankyou again ekrunaj
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
Mr. ­ Messenger
Joined Jan 2005
Feb 01, 2005 07:09 |  #6
Richard Lynch has a book, "The Hidden Power of Photoshop Elements 2", that comes with a CD to enhance Elements 1 & 2. Some of the features that it adds are Channels and Curves. It's not as eloquent as full Photoshop, but at $30 it is a cost effective option that might help you.
Jeff
Pamela107
Joined Nov 2003
Feb 02, 2005 10:24 |  #7
Thankyou Jeff
I checked with Adobe Photoshop 5.0 LE
I found through Image>adjust>curves that I can change red, green, blue channels. Is this maybe the same are that others are speaking about?
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
Pamela107
Joined Nov 2003
Feb 02, 2005 16:09 |  #8
I Called Adobe , Photoshop 5.0 LE cant do channel mixing
They dont have a version that will work with my IMAC
9.2 running system
If anyone can help me find a program that will work with my system , so I can make my IR settings properly, I will greatly appreciate it
Thankyou
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
ekrunaj
Joined Feb 2004
Feb 02, 2005 22:36 as a reply to  @ Pamela107's post |  #9
It seems that PhotoShop 5 LE is really "Lite Edition", not unlike Elements 1,2 and 3; which explains why it is so readily bundled with camera software. I would try to find Photoshop 6 or 7 for mac in the software section of E-bay. Either should be compatible with OS 9.2 and both should have the channel mixer, but do check first. I'm suggesting E-bay because there are a lot of clearing houses online there for "older" software for older operating systems like OS 9.2 for a reasonable price.
Mr. ­ Messenger
Joined Jan 2005
Feb 03, 2005 06:56 |  #10
Pamela,
If you're going to all this trouble, you might consider switching your operating system to OSX. I am running 10.2.8 and love it. It is so much more stable than 9. I resisted it, but would not go back now. I realize this not the answere you're looking for....
Jeff
Pamela107
Joined Nov 2003
Feb 04, 2005 13:29 |  #11
Thankyou ekrunaj / Jeff
I wasnt sure if OSX would cause any problems when changing over, I had heard about serious problems others had when upgrading . I know my new Lacie hard drive and DVD burner are compatible with OSX. Was the upgrade a smooth change or did you have any problems?
I will have to check both of your ideas.
Thankyou
Pamela
Canon Rebel XT
Canon 50 1.4
Canon 70-200 4L
Mamiya 645 Pro
Mr. ­ Messenger
Joined Jan 2005
Feb 04, 2005 18:18 |  #12
Pamela,
I've heard that some people had problems with 10.0 and 10.1. I have had no problems, I started with 10.2.6 and upgraded to 10.2.8 shortly after. I gave our old G3 333mghz Imac (OS9) to our neighbors' daughter, I was a little concerned about what might be left on the hardrive, so I wiped the harddrive and installed an early version of OSX. When we had the Imac it crashed or froze at least every other day. The neighbors report that it is very stable now.
I haven't upgraded to 10.3, but plan to upgrade to 10.4 when it's released. I don't want to upgrade all the time, but I don't want to get left behind either. My current plan is to upgrade to everyother new version.However, I do plan to keep on top of all Adobe Photoshop upgrades. If that involves upgrading my OS, so be it.
Jeff.
1,633 views & 0 likes for this thread, 3 members have posted to it.
IR problem
1570 guests, 130 members online
