Thread started 25 Aug 2008 (Monday) 04:51
550EX II
caseyjohnphotography
Aug 25, 2008 04:51 |  #1
550EX II
if i get 2 and put one on top of cam then one on tripod can i set it to pick up flashes and automatically flash if it sences another flash?
how many can u do it with?
1D Mark III | 17-35 2.8L | 24-70 2.8L | 70-200 2.8L IS| 580EX II | 430EX II | 3 PocketWizard Plus II's
tim
Light Bringer
Aug 25, 2008 05:42 |  #2
Yes, with some caveats. Read the EOS flash bible (external link). If you want it to flash when it sees any other flash you'll need to buy an optical slave (external link). You can also use the built in master/slave system, which is automatic once you learn how to use it - the manual has instructions.
btw it's 580EX II. They're expensive if all you need is manual flash.
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Aug 25, 2008 05:59 |  #3
Can't add much more to what Tim's said... getting a few 580s is an expensive way of getting off-camera lighting, though. For some cheaper ideas perhaps check out the Strobist blog.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
803 views & 0 likes for this thread, 3 members have posted to it.
550EX II
2837 guests, 131 members online
