Thread started 28 Jan 2005 (Friday) 20:21
What went wrong?
epeace
Joined Jan 2005
Jan 28, 2005 20:21 |  #1
I shot a rodeo a few nights ago. I went in knowing I probably wouldnt come away with many keepers due to the fact that the low lighting situation and the fast nature of the action there were not compatible.
I shot these with my 24-700 f/2.8 because my f/4-6.5 just wasnt cutting it at 100 ISO. I did realize later that upping the ISO would have given me a little breathing room but honestly, im not happy with pictures that i take at 2 or 400 ISO.
So heres the first one . . almost there but just not quite on the train to happy town
It gets worse . . .
And finally . .
Im thinking f/2.8 makes for a decently fast lens but should I have gone there with something faster? A 50mm prime maybe (i dont have one but asking for kicks)?
I cant help but think that I could have done something to improve the quality of these shots.
All comments welcome ... . be brutal
/ // epeace / / /
www.ezrapeacephotograp​hy.com (external link)
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jan 28, 2005 20:35 |  #2
What was the exposure time / f-stop on these photos?
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
RockOne
Joined Dec 2004
Jan 28, 2005 20:46 |  #3
Sure looks like difficult lighting conditions. Basically you need to turn the ISO up to the maximum (1600 at least). To stop the action here you may nedd at least 1/250 second or so, so you need all the help you can get. Fast lens + high ISO. You will get a noisy image, but there are programs to deal with that to an extent.You probably have to decide between noise and blur.
Another problem in these situations is you cannot pan with the action as you might be able to get away with at a motor race for example, because the movement is random and unpredictable (which is what makes it exciting I guess
I've tried bullriding shots outdoors at night though (and knew I didn't have a snowballs chance in hell), but didn't get anything nearly as good as you have done here (mainly because I don't have a fast lens yet).
Not sure wether you could get away with using a flash ?. I've seen people using them at these events before. If you can give it a go, and see if it is any good. Doesn't hurt to experiment. It's all experience
(DUPLICATE IMAGE)
I've attached the best one that I managed out of about 20 shots (I gave up flogging a dead horse
(DUPLICATE IMAGE)
Good luck with it.
Steve
EOS300D / EOS30Dx2 / 100-400 L / EF-S 17-55IS /A75 / 75-300mmII / 18-55mm / 28-80mm / 50mm 1.8II / 50-500mm / FinePix S9500. :rolleyes:
epeace
Joined Jan 2005
Jan 28, 2005 20:47 |  #4
exposure time was around 1/30" for these and aperature was pegged at f/2.8
/ // epeace / / /
PacAce
Joined Feb 2003
Jan 28, 2005 20:57 |  #5
Personally, I think these shots have some potential if you can clean it up a bit. Fix the white balance so that the colors are a little more natural looking and sharpen up the images somewhat and you'll have yourself some really good action shots. The motion blur really does something for the shots that you won't get if you had frozen the action with vey high shutter speeds.
You might even try cropping the 1st and 2nd pictures for a little tighter shot to elimiate some of the distracting background.
But for the next time, you might want to consider upping the ISO to 400 and use noise reduction to elimiate the ISO noise.
...Leo
Radtech1
Joined Jun 2003
Jan 28, 2005 20:57 as a reply to  @ epeace's post |  #6
This is from the EXIF data?
Rad
epeace
Joined Jan 2005
Jan 28, 2005 20:57 |  #7
yah i guess i couldnt expect to get "locked shots" under the circumstances . . . thats great that you were able to get a shot from 20 . . . i took a couple hundred shots and this is the best i have to offer . . . :(
/ // epeace / / /
epeace
Joined Jan 2005
Jan 28, 2005 20:58 as a reply to  @ Radtech1's post |  #8
good tip .. yah i like 400 if im going to mess with the iso . . seems to have less artifacts than 200 . . .
Rad
Read from photoshop yes . . .
/ // epeace / / /
ShutteringFocus
Joined Mar 2004
Jan 28, 2005 23:00 |  #9
Well, the rule says that technically you cant even hand hold that lens at 1/30...(wink wink)
Deffinetly your shutter was slow.
Are you really not happy with even 200 ISO? Maybe you should try a noise reducer like Neat Image or something like that.
I find it hard to believe that any of today's cameras wont do at even 800ISO.
tim
Light Bringer
Jan 28, 2005 23:48 |  #10
IMHO it's better to have a nice crisp photo with some noise than a blurry unusable photo at ISO 100. Neat Image or one of the many other noise removal programs will clean up the noise nicely, and in 5 years you can revisit it with the latest software and make it even better. Shooting in RAW's a good idea for this.
I find ISO 400 perfectly fine, ISO 800 ok, and I use iso 1600 or 3200 if I wouldn't have gotten the shot otherwise.
kb244
Joined Jun 2003
Jan 29, 2005 00:45 |  #11
You need least something like 1/125 shutter to capture least some decent movement. Alot of things move faster than the 1/30th shutter, thus the blur. Next time you go back out there lock the aperture into the lowest possible, in aperture priority mode, get the ISO up high enough to where if you pre-shoot the shutter shows up being automatically 1/125 or better.
-Karl Blessing
PHP/MySQL Webdeveloper & Photographer.
My Website (external link)
epeace
Joined Jan 2005
Jan 29, 2005 14:01 as a reply to  @ tim's post |  #12
Well I was only half hand holding the camera . . . had a monopod . . :P
The D60 goes up to 1000 ISO . . . I prefer 400 ISO over 200 ISO . . . A noise reducer would definitely be what the doctor ordered I will check out Neat Image thanks :)
I think I would agree more now than before .. definitely better to have a usable shot that you can clean up than a blurred shot that you can do nothing with . . . . and before all ofyour helpful replies I hadnt thought of cleaning up shots at 200+ ISO with software . . great advice . .
/ // epeace / / /
pcasciola
POTN SHOPKEEPER
Joined Sep 2004
Jan 29, 2005 14:29 as a reply to  @ tim's post |  #13
Ditto.....
The motion blur looks way worse than the noise in this case, and ISO 100 just isn't going to cut it. If you are not willing to use a higher ISO, your only other option is to get a faster, prime lens, like the 50mm f/1.4 or 85mm f/1.8. A 1.4 aperture would have quadrupled your shutter speed to around 1/120, probably still nowhere near fast enough to stop that action, though, but a better starting point that 1/30.
Philip Casciola
Pro Camera Gear (external link) - POTN Shop (external link)
Canon 7D, EF 50/1.8, EF 85/1.8, EF 300/4L IS, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
epeace
Joined Jan 2005
Jan 29, 2005 14:57 |  #14
That makes sense to me . . a f/1.4/8 prime was going to be my next lens anyway . . . now i know for sure i will make good use of it . . that with a 400 ISO should make a dramatic difference at the next rodeo . .
/ // epeace / / /
2,111 views & 0 likes for this thread, 8 members have posted to it.
What went wrong?
1561 guests, 116 members online
