Thread started 28 Oct 2002 (Monday) 11:41
Turn off Sharpening?
tanders1
Joined Jun 2002
Oct 28, 2002 11:41 |  #1
Does anyone know how to completely turn off sharpening on the D60? I know it can be set to low but I'd like to turn it completely off. The Fred Miranda photoshop actions recommend not using any in-camera sharpening but I've no clue how to do this. Any ideas?
Thanks! Tom
Roger_Cavanagh
Joined Sep 2001
Oct 28, 2002 11:52 |  #2
Tom,
Not sure whether the D60 is the same as the D30, but if it is, then the only way to avoid sharpening (and contrast, saturation) is to use conversion from raw to linear TIFF. This would mean using Fred's Linear Pro action (or an equivalent) as linear TIFF files need adjustment to make them usable.
Regards,
Roger Cavanagh
www.rogercavanagh.com (external link)
aneilson
Joined Sep 2002
Oct 28, 2002 11:52 |  #3
If you take the linear conversion option in breezebrowser this is the cleanest image you can get from the chip...........I think. You can then use one of miranda actions in photoshop to convert to RGB. I use the LP llinear D60 action. Ive used this method for the last few weeks and comparing it with normal conversions from raw, im impressed by the differences.
Andy
Sheila
Joined May 2002
Oct 28, 2002 16:37 |  #4
Thanks! Tom
I don't think you can change to absolutely zero sharpening, Tom as digital images do need sharpening. I think Fred means that you shouldn't have your parameters set to High to use his actions but I have mine set to High and still use Fred's CSPro actions and don't find it too sharp! IMHO having it set to High somewhat decreases the need for sharpening after the event. I know I'm going to get an argument here and yes, I do shoot in RAW half of the time! That said, I may just change the parameters to normal and see if there is any visible change to my images.
Cheers
Sheila
Sheila Smart
Sydney, Australia
Canon 5D Mark III and various L primes and zooms
http://www.sheilasmart​photography.com.au (external link)
http://sheilasmartphot​ography.blogspot.com/ (external link)
Roger_Cavanagh
Joined Sep 2001
Oct 28, 2002 17:51 |  #5
If you use the linear conversion, then you _do_ get an image that has no in-camera sharpening applied or contrast and saturation adjustments. Only white balance adjustments can be applied. As Andy pointed out, this is the cleanest image data. I think it's better to use the power of Photoshop rather the more limited capabilities of the camera where possible.
Regards,
Roger Cavanagh
tanders1
Joined Jun 2002
Oct 29, 2002 05:49 |  #6
Thank everyone for your great responses. I guess it's time to buy a larger flash card so I can take all my shots in RAW mode only!
-Tom
gmitchel
Joined Oct 2002
Oct 29, 2002 08:12 |  #7
Use \"As Shot\"
Use the setting "As Shot" for Sharpening in the Canon Raw Image Converter or the TWAIN Interface.
You can do the same with contrast, saturation, etc.
Cheers,
Mitch
2,869 views & 0 likes for this thread, 5 members have posted to it.
1813 guests, 115 members online
