No matter what lens, what focal lenght I use, my 580EXII always says 14mm.
The F-stop is always correct, but the 14mm never changes?
Does it on both camera's also.
Is that normal?
Keithaba Member 211 posts Joined Jul 2008 Location: Louisville, KY More info | Aug 25, 2008 14:21 | #1 No matter what lens, what focal lenght I use, my 580EXII always says 14mm. 40D \ 350D \ 17-55 2.8 \ 70-300 IS \ 60mm 2.8 macro \ 28-135 IS \ Tamron 28-75 2.8 \ 580 EXII
kaitanium Goldmember 3,967 posts Likes: 15 Joined Sep 2005 Location: San Francisco USA More info | Aug 25, 2008 14:24 | #2 if you have that flash head in any position other than pointed and locked forward then it would stay whatever mm it was set to.
Aug 25, 2008 14:26 | #3 Oh yeah, should have mentioned that. That's with it all the way in the foward position. The flash gives you that little icon on the display to signify it's locked. 40D \ 350D \ 17-55 2.8 \ 70-300 IS \ 60mm 2.8 macro \ 28-135 IS \ Tamron 28-75 2.8 \ 580 EXII
Aug 25, 2008 14:27 | #4 ...if you have the built in diffussor pulled out then it will lock onto 14mm. Make sure it's pushed all the way in. (Not in use) 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Make sure the wide-angle panel is not pulled out at all.
mattograph "God bless the new meds" 7,693 posts Joined Jan 2008 Location: Louisville, KY More info | Aug 25, 2008 14:27 | #6 If it says 14mm, you have the wide angle lens down. Flip it back up and push it back into the head. This space for rent.
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | In case you missed it in the massive flurry of posts, check the wide-angle panel
AB8ND Senior Member 745 posts Likes: 3 Joined Dec 2006 Location: Grand Rapids, MI More info | Aug 25, 2008 14:42 | #8 Be sure that BOTH diffusers are pushed all the way home, if either is pulled out only slightly the flash will go to M 14mm.
Aug 25, 2008 16:19 | #9 That was it!!! 40D \ 350D \ 17-55 2.8 \ 70-300 IS \ 60mm 2.8 macro \ 28-135 IS \ Tamron 28-75 2.8 \ 580 EXII
AB8ND Senior Member 745 posts Likes: 3 Joined Dec 2006 Location: Grand Rapids, MI More info | Aug 25, 2008 17:19 | #10 Spend the afternoon at a mountain bike race, trying to figure out what was going on. Keithaba wrote in post #6176282 ....I'm guessing I'm not the first person this happened to? Jack
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 25, 2008 20:15 | #11 Keithaba wrote in post #6176282 I'm guessing I'm not the first person this happened to? Nope, the question pops up most weeks Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member was a spammer, and banned as such! 2837 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
