Thread started 25 Aug 2008 (Monday) 22:21
question about 430ex off camera hookup
Fabian9931
Aug 25, 2008 22:21 |  #1
ok so i just purchased 2 pocketwizards and waiting for them to arrive. and this is what one pocket wizard comes with.... PC-1 Miniphone to PC Cable.... so since i ordered 2 pocketwizards i will have two cables. Right now my plans are to use on pocket wizard on my camera as the transmitter, then the second one connected to my flash. how does the pocket wizard connect to my 430ex? with this pc 1 miniphone to pc cable? or do i need another cable? also same question on my camera... it will be right on my camera hot shoe, do i still need to connect it another way? i also noticed on my 430ex there is a tab that i pulled open and it seems to be a metal plate inside that is threaded, what is this for? if someone can provide pics on the hook up of this set up it would be great thanks
Canon 60D EOS | Canon 50mm f1.4 | Canon 70-200mm IS f2.8 L | Canon 16-35mm 2.8 L II | 430 EX Speedlite x2 | PocketWizard x2 | Alienbee 400 | DIY Beauty Dish for 430ex and AB400 |
DDCSD
GIVIN' GOOD KARMA
Aug 25, 2008 22:40 |  #2
This is what you'll need to hook the PW up to your 430EX.
http://www.flashzebra.​com/wizardcables/hotsh​oe.shtml (external link)
Flashzebra is out of stock, but any good hotshoe to miniphone adapter will work. B&H and Adorama have them as well, but I only have experience with the flashzebra one.
The PW will mount directly to the hotshoe of your camera.
The little threaded plate is simply a bracket hook-up fitting.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
D_CeLiRaToR
Aug 25, 2008 22:41 |  #3
you can use a hot shoe to hot shoe adapter that has a pc output like this:
http://www.amazon.com …hoe-W990560/dp/B00009UU18 (external link)
flash mounts to adapter, pc cable connects adapter to receiver. the transmitter mounts on the camera hot shoe. no cable needed there.
-Mike
Canon EOS Rebel T4i | Canon 70-200mm f/2.8 IS mkII USM| Canon 430EX II
D_CeLiRaToR
Aug 25, 2008 22:53 |  #4
btw i've wondered what that "tab" was for on my 430 also. i assumed canon just used the same shell as the 580ex II which has a pc out untill i saw one in person and the whole thing is much larger.
-Mike
Fabian9931
Aug 25, 2008 22:54 |  #5
thanks guys for the quick response. just orderd a female hotshoe to mini from b and h
PacAce
Joined Feb 2003
Aug 26, 2008 07:12 |  #6
The threaded hole in the EX flashes is used to attach the flash to Canon's SB-E1 flash bracket. It's not much good for anything else as far as I can tell.
...Leo
Fabian9931
Aug 26, 2008 09:57 as a reply to  @ PacAce's post |  #7
thanks pace for the answer on that. it looks kinda crappy because seems to be only 2 threads on that thing... cant wait for my pocket wizards to arrive :lol:
2,164 views & 0 likes for this thread, 4 members have posted to it.
2837 guests, 131 members online
