As we know you can really eat up some disk space as a active photographer.
Enthusiast home user are in a bind because it is hard to justify the cost of quality , redundant, secure disk space to build your portfolio on.
I have what I think is a near perfect solution at a cost well with in the reach of most home users and is good enough to transition to a entry level Business solution.
There are many brands and styles of NETWORK ATTACHED STORAGE devices on the market. Many of the lower end devices are lacking features and reliability which defeats the purpose.
As a minimum I think you should look for the following features:
The Device should be able to support at least two drives in a raid 1( mirrored array) configuration.
Should have a excellent full features embedded web management utility.
Should support Active Directory ( future proof)
Should Support multiple platforms (Windows, MAC, Linux)
Should have 10/100/1000 Ethernet support.
Should have back up utilities.
Should have hot swap drives
Should have a nice case with external power supply and cooling fan
Should have straight forward and easy to use Documentation.
Should have USB external drive and printer support.
Should have Enterprise class bug free management utilities
Should be cheap enough for the home user.
This has been a TALL ORDER in until recently.
There is a company named Promise, well regarded in the enterprise storage world that has come out with a home user NAS device called the NS2300N.
This device is fantastic and totally meets all of the listed criteria.
The device can be purchased for under 200 dollars. Toss in a couple of 500 gigabyte Samsung Sata Drives and you have a terabyte of spinning storage on your home network, safe secure for under 370 dollars.
