You probably shouldn't use strobes and speedlite together, but they work fine. Just make sure the strobes are triggered by cable or radio slaves (I use Skyports
), plugged into the PC sync, and the flash is on the hotshoe. I use manual radio slaves together with ETTL on-camera for weddings as fill.
The reason this isn't really recommended is with studio lighting you use large light sources for a soft light. Add in an on-camera speedlite and you have a small light which will create hard shadows, and maybe side shadow. If you have it on FEC-2 for a bit of fill you might be ok, otherwise you're defeating the purpose of studio lighting.
