Thread started 26 Aug 2008 (Tuesday) 15:46
Can someone school me in the 430ex flash?
DerekRob
Aug 26, 2008 15:46 |  #1
I know there is a big difference in the camera flash to the 430 ex flash, However I'm not quite sure how much of a differnce between the 2 can be?
Like for example if I went out on the back deck of my house and used the night portret shot and then use the 430 EX I can see much more then with the camera flash right?
and 1600 iso shots with the meter all the way tot he left will be much less noise correct?
Titus213
Aug 26, 2008 17:09 |  #2
DerekRob wrote in post #6183978 (external link)
There is a considerable difference in flash power between the 430EX and the built-in flash and that's important. But what is a bigger difference is the ability to point the 430EX for bounce flash. Most folks looking for better quality images refrain from pointing the flash directly at the subject whenever possible. That is NOT possible with the built-in flash.
But there is a limit. While noise increases in shadow/dark areas the 430EX flash will give you more light and more controlled light than the built-in unit. I would also invest in a good noise removal package such as Neat Image, Noise Ninja, etc.
Dave
Perspiring photographer.
DerekRob
Aug 26, 2008 17:11 |  #3
Titus, Thank you.
Now is it true that the ex series flash like the 580 or the 430 can be used in doors with out the "flash lite going off and bugging everyone?'
Because I want to go into a blues club and take a few photos of everyone playing.
Titus213
Aug 26, 2008 18:26 |  #4
You can generally turn off the flash and just use its focus assist, yes.
Dave
DerekRob
Aug 26, 2008 18:29 |  #5
Titus213 wrote in post #6184979 (external link)
Oh nice, I've wondered how they do that when your in places like a wedding and what not.
Titus213
Aug 26, 2008 18:47 |  #6
Actually I have not been able to figure this out now. Best double check your manual.
I'd swear I've done this.
Dave
Warrenism
Aug 26, 2008 18:48 |  #7
... 1600 iso shots with the meter all the way tot he left will be much less noise correct?
I'm no pro, but i would think if you had your meter all the way to the left, you are going to lose a lot of detail/information. As such your image will be quite dark.
Only the 580 EX can support having the flash turned off but using its IR focus assist.
[DSLR-less | 10-22 | 24-70L f2.8 | 70-200L f2.8 IS | 24-105L f4 | 50 f1.4 ]
Flickr (external link) | Warrenism: Blog Rantings (external link)
Titus213
Aug 26, 2008 18:51 |  #8
Warrenism wrote in post #6185125 (external link)
I would think so too.
Seems to be a function of the body too....???
https://photography-on-the.net …59&highlight=fo​cus+assist
Dave
D_CeLiRaToR
Aug 26, 2008 18:57 |  #9
also the st-e2 has focus assist. if you want to use your 430ex as a focus assist only you have to set the camera to one shot focus with the flash on, lock focus and then switch the lens to manual focus, then turn the flash off and shoot. not always possible to do in some situations.
-Mike
Canon EOS Rebel T4i | Canon 70-200mm f/2.8 IS mkII USM| Canon 430EX II
DDCSD
GIVIN' GOOD KARMA
Aug 26, 2008 19:16 |  #10
You can do it with the 430EX. I do it all the time. It is a Cfn in the camera. You can set the flash to "Does not Fire". On the 40D it is in the flash control menu.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
Warrenism
Aug 26, 2008 19:21 |  #11
D_CeLiRaToR wrote in post #6185194 (external link)
Just reading that workaround gives one a headache :P
Alternative is to get the focus off the shutter button and on the * instead.
DDCSD wrote in post #6185296 (external link)
Your right DDCSD, it is a camera featu :)re. Now to eat my own words and 400D so i can get a new xxD.
D_CeLiRaToR
Aug 26, 2008 19:22 |  #12
appears that's only in certain cameras and doesn't work with the rebels. i remember trying to find the cfn in my xt and it wasn't there.
-Mike
DDCSD
GIVIN' GOOD KARMA
Aug 26, 2008 19:24 |  #13
D_CeLiRaToR wrote in post #6185333 (external link)
Hmmm... That's too bad, it is very handy. Thanks for the clarification.
Derek
D_CeLiRaToR
Aug 26, 2008 19:33 |  #14
i wonder if they make a solid black "diffuser" similar to a stofen to cover the flash head but still use the focus assist? or would that burn out the flash?
-Mike
Titus213
Aug 26, 2008 19:35 |  #15
Duct tape?
Point the flash up and run the power down to the lowest setting?
Dave
2,182 views & 0 likes for this thread, 8 members have posted to it.
2748 guests, 137 members online
