Thread started 26 Aug 2008 (Tuesday) 21:23
Wireless Transmitter for Canon 580
canon ­ shooter
Aug 26, 2008 21:23 |  #1
I am looking for a good wireless transmitter to control my Canon 580EX, and then let that trigger my White Lightening WL 5000 as a slave.
What are my choices? What luck are others having doing this?
I have looked at the Smith - Victor RTK-4 and the Canon ST-E2, which will work better for this and still work as ETTL?
Looks like the SV is much cheaper ($84 @B&H vs. $220 for Canon).
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
tim
Light Bringer
Aug 26, 2008 23:40 |  #2
If you try and trigger a studio strobe optically using ETTL the preflash will set of the strobe before the shutter's open. It doesn't work.
If you want ETTL for your 580 you'll need a cord or radio slave for the strobe, which has to be in manual. I use skyports (external link), hooked up via the PC port of the camera.
canon ­ shooter
Aug 26, 2008 23:51 as a reply to  @ tim's post |  #3
Good point.
But if I use one of these two transmitters and use 580 in manual, assume it would work and it will fire studio flash as slave?
Just won't be able to us ETTL??
Jim
tim
Light Bringer
Aug 26, 2008 23:53 |  #4
Yep 580 in manual mode will trigger it. Using that transmitter with the radio system and the flash in ETTL or manual will be fine too.
canon ­ shooter
Aug 31, 2008 21:47 |  #5
tim wrote in post #6187056 (external link)
OK now trying to decide between the Canon ST-E2, the Skyport, or the Pocket wizard Plus II. But still have some questions.
I THINK the Canon ST-E2 will only control a Canon Flash, not the studio flash. But I know the 580EX could be on Master and studio on Slave, but don't think I could use it to control the studio without the canon 580??
I think the Skyport comes with both transmitter and receiver so I could use it to control either 580 or studio flash, but sounds like it does not come with cable for 580 (but does for studio).
Not sure how the PocketWizard works. Looks like it only has one piece, so will it control or trigger either the 580 or studio??
Jim
tim
Light Bringer
Aug 31, 2008 22:13 |  #6
ST-E2 will only control Canon EX flashes. If you use wireless ETTL then the preflash will trigger the studio strobes before the shutter is open. In manual they'll be fine, they'll trigger the studio flash fine. I don't know why you'd be using ETTL at the same time as a studio strobe anyway.
The skyport kit comes with a transmitter and receiver. With this in the PC port you could use wireless ETTL with the receiver on the studio strobe. You can get a hotshoe to 3.5mm plug from flash zebra or from B&H (external link) pretty cheaply.
O3DigitalBath
Aug 31, 2008 23:12 |  #7
canon shooter wrote in post #6216825 (external link)
Yes, it will fire either. You would have to buy one for the camera, then one for every flash you want it to fire (or use splitter cords, not always recommended)
If you decide to go with one of the wireless trigger options as opposed to the ST-E2 you will lose your ettl (auto), but will gain distance and reliability. The infared systems work well in line of sight (sometimes can bounce off walls). In exchange you will gain distance and reliability. Also as far as I know you can't trigger a stuido flash with the infared (could be wrong, this wouldn't be hard to make..but i'm sure it wouldn't work with ettl either)
Alienbee's cybersyncs and the skyports are a bit cheaper solutions. I'vear heard great things about the skyports but havn't used them and can't speak from any experience. I'm currently using the cybersync's with 430ex and I coudln't be happier.
Facebook Photo Page (external link)
Website (external link)
canon ­ shooter
Aug 31, 2008 23:18 |  #8
tim wrote in post #6216917 (external link)
Well if I shoot in Manual and use Flash meter for exosure with the Canon ST-E2, it should trigger the 580 fine and if the 580 is in "Master" mode, it should trigger the studio??
On the Skyport sound like it comes with cable to plug directly into studio without any computer being involved?? Then the 580 could be in "Slave" mode and it would be triggered by the studio??
Sorry to ask so many questions but want to make sure I buy the right product so that I can trigger the the 580 and/or the studio
Jim
O3DigitalBath
Aug 31, 2008 23:21 |  #9
canon shooter wrote in post #6217219 (external link)
skyport should plug into any of the flashes (adapter might be required) and that will trigger it. If its plugged into the 580 and the studio has a optical slave built in then yes it would fire, if not it would need a receiver as well.
O3DigitalBath
Aug 31, 2008 23:28 |  #10
just looked up the White Lightening WL 5000...looks like it does have a optical slave built in.
so for expample if you put the skyport transmitter on your camera, then plugged the receiver into your flash...when that flash fires (580ex) it should fire your studio (wl5000).
If you later on wanted to get another skyport, if you plugged that in it would disable the optical slave on the WL5000 and would be triggered by the skyport (better range and reliability)
PacAce
Joined Feb 2003
Aug 31, 2008 23:39 |  #11
Canon ETTL wireless remote and optical slave triggering do not mix, even if the EX flash is operated in manual mode. The reason is because the ST-E2 or the master flash will prematurely trigger the studio strobes. The only way to prevent this is to trigger the EX flash with an RF remote (i.e. SkyPort, PW, etc.) or a sync cable.
...Leo
canon ­ shooter
Sep 01, 2008 00:09 |  #12
Tim, can you use the 3.5mm plug to fire the 580 in ETTL or manual?
Jim
tim
Light Bringer
Sep 01, 2008 00:10 |  #13
I've never tried wireless ETTL in manual, but I bet Pacace is right. I have used strobes and 580's together, but all triggered using skyports.
tim
Light Bringer
Sep 01, 2008 00:11 |  #14
canon shooter wrote in post #6217409 (external link)
Any slave of any type, studio or speedlite, can only operate in manual when ratio slaves are used. RadioPoppers are the only exception I know of, as they're not a simple radio slave.
canon ­ shooter
Sep 01, 2008 00:12 |  #15
tim wrote in post #6186997 (external link)
Tim, so the set up you are talking about here is a Skyport on camera with receiver on studio, and then the 580 in Slave??
Assume with this set up you use a flash meter??
Jim
4,399 views & 0 likes for this thread, 8 members have posted to it.
2888 guests, 133 members online
