Thread started 27 Aug 2008 (Wednesday) 08:10
Is this right?
daystar
Aug 27, 2008 08:10 |  #1
I'm playing around with manual mode and trying to understand histograms so the pic isn't very interesting but I wanted to know if you think it's exposed correctly.
Nikon D750 | Nikon D7100 | 85mm 1.8G | 50mm 1.8G | 35mm 1.8G | Tamron 70-200 2.8
Mike ­ McCusker
Aug 27, 2008 08:34 |  #2
Looks slightly overexposed to me. Some pping could bring it back...
20D with grip, 50D,Canon 50mm 1.8II,Canon 18-55,Canon EF 24-105mm IS, Canon 70-200 2,8L, Canon EFS 17-55mm f/2.8 IS USM, Sigma 10-20mm f/4-5.6, 580EX, 430EX, ST-E2
No one goes through life undefeated!
KarlosDaJackal
Aug 27, 2008 08:38 as a reply to  @ Mike McCusker's post |  #3
exposure is not a science its subjective and can be used creatively ;)
I would also say its a little bit over exposed just because the grass in the background seems very bright.
My Website (external link) - Flick (external link)r (external link) - Model Mayhem (external link) - Folio32 (external link)
Gimp Tutorials by me on POTN
daystar
Aug 27, 2008 08:53 as a reply to  @ KarlosDaJackal's post |  #4
Interesting. I was going off what the meter said was correct and how the histogram looked. Boy, I've got alot to learn!:)
Pete
Aug 27, 2008 08:55 |  #5
The stick and foreground appear to be properly exposed, but the background looks a little bright. This would concur with if your exposure meter (I assume you're using your camera for this) is set to centre weighted.
Pete
UK SE Catch of the Day
daystar
Aug 27, 2008 10:58 |  #6
Pete wrote in post #6188919 (external link)
Aha! Yep, center weighted! I was in manual mode and the is the automatic setting. Does anyone know if I can change that in manual? I've got the 300D and my owner's manuel doesn't say - it just describes the different metering modes.
KarlosDaJackal
Aug 27, 2008 12:41 |  #7
daystar wrote in post #6189667 (external link)
I've a 400d and the metering mode is changeable in manual and automatic modes, so i should be the same on yours. to change it you press left on the direction pad, and then you get the 3 options.
joedlh
Gallery: 52 photos
Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea.
Aug 27, 2008 13:04 |  #8
The darkest parts -- spots on the trunk -- are black and the lightest parts are not blown out, yet it appears slightly overexposed. However, it appears to be tonally flat to me. Here it is with adjusted levels in PS Elements. The pink indicated spots are the new levels.
Joe
Gear: Kodak Instamatic, Polaroid Swinger. Oh you meant gear now. :rolleyes:
http://photo.joedlh.ne​t (external link)
Editing ok
griptape
Aug 27, 2008 14:25 |  #9
It depends on what your subject is. The most important part is to get your subject properly exposed. The foreground and/or background sometimes have to be sacrificed due to the limitations of dynamic range. Shoot something with an actual subject if you're trying to learn how to expose properly.
943 views & 0 likes for this thread, 6 members have posted to it.
Is this right?
2743 guests, 148 members online
