Thread started 27 Aug 2008 (Wednesday) 10:30
3 flash guns, two receivers...can it be done?
namasste
Aug 27, 2008 10:30 |  #1
I was wondering if I could mount my Sigma 530 on camera and then attach my skyport trigger to the camera via a pc/hotshoe setup of some sort. I'd have two Viv 285 HVs off camera with receivers and thus a three light setup.
My reasoning is that I have had troubles firing the Sigma consistently with the Skyports but never when on camera. For shooting HS sports, this would allow a nice strobist setup off camera with the addition of some "mobile" lighting on camera. If it can be done, I think the results would be fantastic (although I'd need to invest in Eveready or some Quantums..)
Scott Evans Photography (external link)
SportsShooterProfile (external link) l MaxPreps Profile (external link)
bishop13
Aug 27, 2008 11:14 |  #2
This might suit your needs.....but I got confused by the description. I think its time for some coffee.
http://www.bhphotovide​o.com …versal_Flash_Ad​apter.html (external link)
Headshotzx
Aug 27, 2008 12:21 |  #3
namasste wrote in post #6189448 (external link)
My friend mounted a ST-E2 on the hotshoe and an ebay-trigger in the PC hole, and he triggered 2 580EXIIs (using IR) and 3 Vivitar 285HVs. I'm sure you'd be fine, just make sure the sigma is on manual, if not it's going to be overexposed, if you get what I mean.
Zexun | Flickr (external link) | YouTube (external link) |
namasste
Aug 27, 2008 13:05 as a reply to  @ Headshotzx's post |  #4
thanks! Bish....I don't think it's the coffee, that may be the best/worst description ever written. My brain hurts.
NathanJK
Aug 27, 2008 15:24 |  #5
Wow, I figured out how that thing works...but they sure don't make it easy on you do they? I loved all the quotes... "hot" shoe!
http://www.shuttersnap​studios.com (external link)
http://shuttersnapstud​ios.wordpress.com (external link)
bishop13
Aug 27, 2008 15:25 |  #6
Cuz "quotes" are "cool".
namasste
Aug 27, 2008 16:01 |  #7
bishop13 wrote in post #6191328 (external link)
yeah, like taking the vowels outta words...straight pwn3'd eh grls?
FlashZebra
This space available
Aug 27, 2008 17:52 |  #8
Scott,
The Skyport comes packed with a short cord that will allow you to connect the sync port on the Skyport transmitter to a PC port on the camera.
Just connect as above and attach a piece of velcro on the Skyport transmitter and stick it on the Super Sigma flash somewhere.
The Skyport transmitter is so light it should not take much to secure it.
You should not need to purchase anything other than some velcro.
Enjoy! Lon
namasste
Aug 28, 2008 08:28 |  #9
FlashZebra wrote in post #6192224 (external link)
Scott,
Enjoy! Lon
Thanks Lon. Embarassed to say that I didn't think the trigger had a port:o:o
Big ­ Mike
Aug 28, 2008 13:54 |  #10
I've use a cactus trigger in the same way. Transmitter connected to camera via PC port and triggers remote flash. Separate flash sits on the hotshoe. I can even keep the on camera flash in E-TTL.
Instructor at The Canadian Photography Learning Centre (external link).
Blog (external link)
namasste
Aug 28, 2008 15:10 |  #11
Big Mike wrote in post #6197924 (external link)
this is all great news!!! the main issue being that the Sigma does not fire consistently when connected to the receivers but the Vivs fire just fine. The Sigma also has to be in optical mode (although theoretically you can use C1 or C2 but I've had no success there) which means it fires anytime another flash fires unless its sensor is covered.
The other great thing is that the Vivs recycle slower than the Siggy so if I put the Sigma on ETTL, I'll be able to catch a few in between shots while the Vivs recycle. The additiaonl light when all three go will be awesome! Woohoo! Heck, I might even be able to bounce the two Vivs and fire the Sigma on a bracket and still have no shadowing. Time will tell.
1,301 views & 0 likes for this thread, 6 members have posted to it.
2743 guests, 137 members online
