You have the hardware you need to shoot prime focus with your Schmidt-Cassegrain(C-11) and a DSLR. There's no need for a lens, the telescope will be your lens, and a hefty one at that. Taking deep sky photographs(long exposure) at 2800mm is difficult for those with experience so be prepared for some challenges but don't be discouraged. The CG-5 mount is bare minimum for imaging with an optical tube of this size/weight and focal length. The scale achieved with this kind of focal length is wonderful but with the increased scale comes the need for pin-point accurate tracking and careful balance and alignment of the scope when you set up. When focal length is increased so is the apparent movement of Earth as it rotates on its axis.
I highly recommend that you pick up the Celestron f/6.3 focal reducer/flattener. The C-11 is an f/10 scope and that's VERY slow for deep sky objects but fine if you plan only to shoot Lunar or planetary. Initially you'll have to find the exposure lengths this rig will allow you and work within that frame work. Unfortunately the CG-5, as I mentioned will be your biggest challenge. The mount used for any rig is the single most important element for long exposure work. If a mount is maxed out with weight it will make balance at set up extremely critical and will also push the internal components(gears, etc.) to their limit. I'm not saying you won't have success, just that there will be limits in exposure times, which you'll have to determine by testing.
I would suggest you begin with the Moon and brighter deep sky objects like the Orion Nebula(M42). These type of objects will allow you to get a feel for your rig as well as determine its limitations. Astrophotography has a steep learning curve, takes enormous patience and can get expensive but its extremely rewarding when you see those successes appear on your monitor.
Dark skies will be important for long exposure work. If it's not dark where you live you might want to scout a darker site within a short drive.
One other thing, you'll want to use a shutter release cable(manual or digital) for long exposure work. Avoiding vibrations will be a must. You could get by with the camera timer delay for Lunar and planetary for now but it's really not practical for multiple long exposures.
Stop by the astrophotography thread in the Nature/Animal section. We'd be happy to help you with any questions you may have.
https://photography-on-the.net/forum/showthread.php?t=553708
