Thread started 28 Aug 2008 (Thursday) 12:04
ST-E2 for basketball
strobe ­ monkey
Aug 28, 2008 12:04 |  #1
Anyone using Canon ST-E2 transmitter for off camera flash in basketball games ???
I am very happy with my Cacyus V2s reliability but I need to sync at high speed hence my question.
Is there any alternative except the expensive Pocket Wizard???
I don't need ETTL just high speed sync.
R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
aram535
Aug 28, 2008 13:18 |  #2
I don't think the ST-E2 is a vaiable choice as it does not bounce very well. A regulation ball with proper PSI is better.
Where exactly do you shoot that you're allowed to use flash?!? I have never seen a stadium that allows flash.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
Big ­ Mike
Aug 28, 2008 13:43 |  #3
A pocket wizard won't give you high speed sync...only up to the camera's max 1/250.
The ST-E2 (or a second 580) will give you the ability to use HSS remotely...but note that HSS does greatly limit your working distance. This set up would also be limited by the IR connectivity which might not be a factor indoors, but outdoors it would probably require line-of-site.
Instructor at The Canadian Photography Learning Centre (external link).
Vascilli
Aug 28, 2008 13:59 |  #4
What about Radio Poppers?
Flickr (external link) | Gear List
strobe ­ monkey
Sep 01, 2008 07:29 |  #5
Vascilli wrote in post #6197959 (external link)
Thy are expensive. Maybe the jr. when they are available and if they can sync at high speed with my Canon.
SkipD
Joined Dec 2002
Sep 01, 2008 07:41 |  #6
strobe monkey wrote in post #6218627 (external link)
Are you aware of how Canon's ETTL "high speed sync" really works? What it does is emulate a conventional (non-flash) light source by emitting a fast series of very weak flash pulses for the duration of the shutter's movement.
Most folks only use it for flash fill in bright lighting situations.
Skip Douglas
strobe ­ monkey
Sep 01, 2008 09:56 |  #7
SkipD wrote in post #6218669 (external link)
I didn't know until now:D. Thanks!
1,553 views & 0 likes for this thread, 5 members have posted to it.
2797 guests, 138 members online
