Thread started 28 Aug 2008 (Thursday) 13:01
Help! My head is spinning with all of this Flash knowledge!
michillebaker
Aug 28, 2008 13:01 |  #1
I just read all of the information from the "all about flash links thread" and wow that was alot to take in.
Now forgive me as i am a beginner and plan on in the next couple months buying my first external flash unit. I probably going to get the 530ex or maybe even the 580ex but I haven't decided yet on everything i need. I was hoping i could get your help.
My questions are
1. I were to just by the flash unit and not anything else can on use it as an on board flash unit?
2. Also i would prefer since the reason for me buying this would be to get alot better indoor quality picture to actually use the flash off camera. What would be everything i would need for the basics to be able to acomplish this.
3. Also, one other thing. I did see another post were they talked about lighting and how its better to have more than one source of light to create a better pic indoors. They showed pictures of what I think looked like a light bulb that they screwed into a lamp, do I have to have some kind of lamp for that?
Thanks,
Michille
Not a pro by any means.. Just enjoy taking pics.
Gear: Canon 60D, Rebel XSi; Canon 50mm ; Canon 55-250mm IS ; Flash: Canon 430ex II with diffuser My Just order sigma 18-50mm :).
My Photo Blog (external link) ; My Actions & Tutorial Blog (external link) ; My flickr (external link)
http://michilles-photography.blogspot.c​om/ (external link)
Wilt
Aug 28, 2008 13:10 |  #2
1. Yes.
2. Master use on camera first, then branch out to off-camera. Since you are a beginner, you will likely be reliant on ETTL flash automation. The only way to accomplish that is to get a very long (not from Canon!) off-shoe extension, with contacts that mimic those on your camera hotshoe. Or to get an even more expensive Canon ST-E2 wireless transmitter unit. All other 'remote' flash lose ETTL functionality, so they require totall Manual flash control and exposure calculation, unless you buy a flash that has an Auto mode (which 430EX or 580EX do not have...580EX-II does have this)
3. Any old ordinary lamp and bulb can be put to this usage, but you will need to make sure your camera is set to AWB, or even better that it is set to Tungsten White Balance. But caution that you do not try to use this at the same time as Daylight balance light is in the room.
aram535
Aug 28, 2008 13:15 |  #3
My first external flash was a 430EX and its been a great run. Now I have 2 430EXs, 580EX II, and now switching to AlienBees. The 430 and 580 will be my travel show. :-)
Can't go wrong with the 430EX. If you're going to be using as your main and only light for portraits, I think the best recommendation is to move it off of the camera. Either by a short cable and hand holding it or with a flash bracket to hold it up and over.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
michillebaker
Aug 28, 2008 13:55 |  #4
Awsome, you both answered my questions wonderfully. Thanks!
Michille
hastur
Aug 28, 2008 15:01 |  #5
1 - Yes
2 - I'm having good enough results with http://www.abetterboun​cecard.com (external link) that I haven't needed anything else yet for indoor photos. Others like the lumiquest products.
3 - There are flashes/strobes that screw into a standard light bulb base. I'd start with on camera, move to off camera and then off camera with a reflector before adding a second light.
Some thoughts
Rob
How can you trust a man who wears both a belt and suspenders? The man can't even trust his own pants. - Frank (Henry Fonda) in Once Upon a Time in the West.
20D, 17-55, 35-70 f/3.5-4.5, 50 f1.8, 85 f/1.8, 430EX
877 views & 0 likes for this thread, 4 members have posted to it.
2743 guests, 137 members online
