Thread started 28 Aug 2008 (Thursday) 15:41
What's a good, cheap flash?
Matthew ­ Hicks ­ Photography
Aug 28, 2008 15:41 |  #1
More specifically, I want something that will just plain work on my 40D. I rarely use flash, in fact THIS (external link)is about the only thing I ever use it for, and you can see the problem. What's a cheap solution?
Calgary Wedding Photography by Matthew Hicks: www.matthicksphoto.com (external link)
Lotto
Aug 28, 2008 15:50 |  #2
I see the shadow from your wild angle lens :) If you know how to use manual flash, a Sunpak 383 is about $90.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Aug 28, 2008 15:51 |  #3
If I can learn how to use a manual camera, I can learn how to use a manual flash ;)
Sounds like it's just what I need.
Titus213
Aug 28, 2008 15:52 |  #4
Well, that image is interesting enough that you need some better lighting so we can see more.
I think your best bet would be a 430EX. It fits the good part, you decide on cheap at about $240. It is the bottom of the usable Canon line. (isn't that sad? $240 is the bottom of the line?) Since it's a Canon EX flash it will be compatible with your 40D.
Your lens is another matter. At 10mm I can't tell you how the flash will look. I know the pull down panel is supposed to be good to 14mm. Since I can't go wider than 16mm I have no experience there.
Unless as stated above you can go to manual flash.
Dave
Perspiring photographer.
1,708 views & 0 likes for this thread, 3 members have posted to it.
2743 guests, 137 members online
